600bhp And 450ft/lbs
Geo
You could get 1 car that makes 450 ftlbs @ 5000 rpm & one car that makes the exact same torque only higher in the rpm range, say 6000 rpm.
So car 1 has 428 bhp & car 2 has 514bhp, nearly 90bhp difference. One that makes 450ftlbs @ 7000 rpm is 600bhp.
So depending on setup (turbo, cams etc) it's not too strange to have those figures, it's all about where the car makes it's torque in the rpm range.
The higher rpms allow you to gear down. As an example, imagine 2 cars both make the same torque, one at roughly 1500rpm higher than the other. They are side by side, obviously one car needs to be in say 3rd gear & 1 in 4th gear to maintain the same speed but keep each in it's peak torque area. They both put their foot down, the one in 3rd gear will pull away faster (obviously).
