How do you get an auto off the line quickly?
Crazybassist
Hi all, Last night was my first time on the drag strip with my supra, and my first time with an auto! Before I prided myself on getting my manual BMW off the line like a rocket, even if it wasn't the quickest up the strip. But last night I kept getting raped cos my starts were so sluggish.
Is there a trick to getting an auto off the line? I tried holding it on the brake and getting some revs up but she didn't seem to happy with that. So I then just planted it from nothing and had to wait for the turbos to kick in. By which time the Evo's and Impreza's had gone! :rolleyes:
The next race is on the 24th of July, and I'm hoping to have a boost controller fitted by then to give me more of a chance, but getting a good start is so important!
for a more spirited start from standstill I tend to switch to Manu mode, into L, left foot brake while building up some revs (not for too long) then off the brake and away you go :) shifting through to 2 then D as necessary
too much revs and you will just wheelspin and not enough and you have to wait for boost to come on.
i scream as loud as i can out the window which distracts the person i want to race, then stamp as hard as i can so the kick down lauches the car off the line.... leaving the ford ka for dust
lol
power brakeing (holding it on the brake building as much revs as you can) is the best way ive found. but it takes a while to find out how high you can rev it before the rear wheels brake traction on the start line. At the pod its generaly better because of the sticky track. but at thunder road on an airfield i had a hard time so i just didnt bother so much. Still managed to come out with a high 12 1/4 time though.
Your not going to be able to beat an evo or a scooby over the 60ft or 1/8th mile. but by the 1/4 you shuld be realing them in. If the 4wd boys are risking full launches off the line they are going to achive a couple of things. Braking something or beating you by a long way anyway.
from what ive seen 4wd cars that launch properly are always running very good power and the supporting driveline mods for it. or they brake something sooner or later :p
Into D with foot on brake.
Release handbrake while checking all mirrors.
If safe to proceed accelerate briskly to speed limit.
:D
Do brake boosting hurt or damage the auto transmission in the long run?
It can boil the transmission fluid if you do it for to long
you dont need to do it for very long. just a few seconds. You get the hang of it after a few runs. And when its at events where they time you from the moment you trigger the timers at the start rather than when the light goes green its not an issue. Just do it when your ready and forget about the green light and being first off the line :p
unless your lucky enough to have a trans cooler fitted or have a uk spec which i think came with one.
Edited by Guigsy (see edit history)
That's my worry too, my mate who has an auto said it's a bad idea to do it after seeing me do it in my car :D
Nah, you can hold it on the brake for a good few seconds without cooking things, if you need more than 5 seconds to get the revs right you probably shouldn't be driving :D
