Guest Suprastar2009 Posted June 19, 2010 Share Posted June 19, 2010 after a purge valve kit for my nitrous kit single or twin nozzle, what have you got ? Link to comment Share on other sites More sharing options...
hodge Posted June 19, 2010 Share Posted June 19, 2010 ebay dude. Link to comment Share on other sites More sharing options...
Guest Suprastar2009 Posted June 19, 2010 Share Posted June 19, 2010 Nope, thanks for the suggestion just checked it out nothing cooking Link to comment Share on other sites More sharing options...
hiten55 Posted June 19, 2010 Share Posted June 19, 2010 here ya go: Linky Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 19, 2010 Share Posted June 19, 2010 these look ober cool! And im not affraid to admit that an ILLUMINATOR KIT would add to the cool effect.. I know there for cleaning the NOS lines of air pockets but still cool either way lol... Link to comment Share on other sites More sharing options...
SupraHuman Posted June 19, 2010 Share Posted June 19, 2010 Why would you need a purge kit on an N/A? Waste of Nitrous oxide if you ask me. Link to comment Share on other sites More sharing options...
dude Posted June 19, 2010 Share Posted June 19, 2010 Nitrous don't work without a purge dude;) you just get extra fuel and no NOS:search:, You can use and nitrous solenoid and make a braided line using -3 or 4 hose. Link to comment Share on other sites More sharing options...
Guest Suprastar2009 Posted June 19, 2010 Share Posted June 19, 2010 Nitrous don't work without a purge dude;) you just get extra fuel and no NOS:search:, You can use and nitrous solenoid and make a braided line using -3 or 4 hose. I want the valve that clears the lines of left over nos in the pipes, ive read it gives a better response, better temp etc. It also looks cool when you pull upto the line and shoot the gas out Is this what you were on about? Link to comment Share on other sites More sharing options...
SupraHuman Posted June 19, 2010 Share Posted June 19, 2010 Nitrous don't work without a purge dude;) you just get extra fuel and no NOS:search:, You can use and nitrous solenoid and make a braided line using -3 or 4 hose. I was on about the F&F style venting to atmosphere puge kit dude. Link to comment Share on other sites More sharing options...
JamieP Posted June 19, 2010 Share Posted June 19, 2010 All purge kits vent to atmosphere, purge kit is worth fitting if you want to use the nitrous out of a dig. Link to comment Share on other sites More sharing options...
dude Posted June 19, 2010 Share Posted June 19, 2010 I was on about the F&F style venting to atmosphere puge kit dude. Unfortunatly the only way to get clean nitrous to the solenoid is to vent the gas from the line, when it goes to the vapour its purged, its THEN a waste of NOS Link to comment Share on other sites More sharing options...
SupraHuman Posted June 19, 2010 Share Posted June 19, 2010 All purge kits vent to atmosphere, purge kit is worth fitting if you want to use the nitrous out of a dig. I never had a venting to atmosphere kit on my previous (wizard of nos) kit, if you want to get a kit just to blast good nitrous out into the night sky that's a waste in my opinion. Link to comment Share on other sites More sharing options...
JamieP Posted June 19, 2010 Share Posted June 19, 2010 I never had a venting to atmosphere kit on my previous (wizard of nos) kit, if you want to get a kit just to blast good nitrous out into the night sky that's a waste in my opinion. Where does it vent to when you purge then? Link to comment Share on other sites More sharing options...
dude Posted June 19, 2010 Share Posted June 19, 2010 I never had a venting to atmosphere kit on my previous (wizard of nos) kit, if you want to get a kit just to blast good nitrous out into the night sky that's a waste in my opinion. If it makes you feel better you can always point the purge at the FMIC ti cool it, but a NOS kit will NOT work properley unless it is purged FACT, you will not run quicker over a 1/4 because you lose as much as you gain while its running too rich due to excess fuel, same as it needs 'mapping' as much as an ecu does. Link to comment Share on other sites More sharing options...
Guest Suprastar2009 Posted June 19, 2010 Share Posted June 19, 2010 So now weve established its cool and I do need one does anyone have one? Link to comment Share on other sites More sharing options...
JamieP Posted June 19, 2010 Share Posted June 19, 2010 So now weve established its cool and I do need one does anyone have one? http://www.noswizard.com/product_desc.php?id=7 Link to comment Share on other sites More sharing options...
dude Posted June 19, 2010 Share Posted June 19, 2010 Theres loads on ebay, you only need to spend about $70, get hold of Wiggy he got a cheap one but don't mention me as I had a dispute with the ebay seller he used. Link to comment Share on other sites More sharing options...
SupraHuman Posted June 19, 2010 Share Posted June 19, 2010 Where does it vent to when you purge then? I did not purge, just had to let the car bog down until the gas was ready @ the solenoid. It only takes a split second for the gas to reach its destination, purge kit is in my opinion for a serious dragster that need the nos @ the solenoid before launch. Link to comment Share on other sites More sharing options...
dude Posted June 19, 2010 Share Posted June 19, 2010 I did not purge, just had to let the car bog down until the gas was ready @ the solenoid. It only takes a split second for the gas to reach its destination, purge kit is in my opinion for a serious dragster that need the nos @ the solenoid before launch. Why would you fit something that cost maybe £800 and not let it work to its full advantage, like putting a garrett turbo on an XS Power manifold, yes it will work but not as well as it should. remember 1/10 lost or gained costs or gains 3/10 at the finish line so your little stumble could well cost over .5 second. Link to comment Share on other sites More sharing options...
dude Posted June 19, 2010 Share Posted June 19, 2010 Should you be using a nitrous system with braided supply hose then it’s a whole different matter, as a purge kit becomes an essential part of a nitrous system if you wish to achieve optimum performance. A purge solenoid can also be used to empty the supply line when the system is not to be used, to ensure no nitrous leaks past the solenoid seal in to the engine. Link to comment Share on other sites More sharing options...
SupraHuman Posted June 19, 2010 Share Posted June 19, 2010 Why would you fit something that cost maybe £800 and not let it work to its full advantage, like putting a garrett turbo on an XS Power manifold, yes it will work but not as well as it should. remember 1/10 lost or gained costs or gains 3/10 at the finish line so your little stumble could well cost over .5 second. I think you mistake me for somebody who does drag racing for a living dude. Link to comment Share on other sites More sharing options...
dude Posted June 19, 2010 Share Posted June 19, 2010 I think you mistake me for somebody who does drag racing for a living dude. No I think you are someone who builds a car to the best of your ability and funds who also does not like losing an argument.....which you have, fact, for a nitrous kit to work to the best of its abilty you need a purge kit;) Link to comment Share on other sites More sharing options...
SupraHuman Posted June 19, 2010 Share Posted June 19, 2010 No I think you are someone who builds a car to the best of your ability and funds who also does not like losing an argument.....which you have, fact, for a nitrous kit to work to the best of its abilty you need a purge kit;) I don't build it dude, Martin does. Link to comment Share on other sites More sharing options...
dude Posted June 19, 2010 Share Posted June 19, 2010 I don't build it dude, Martin does. Then Martin should know to send you the bill for a purge valve:eyebrows: Unless of course the nitrous kit will just be for show/bragging rights:search: Link to comment Share on other sites More sharing options...
SupraHuman Posted June 19, 2010 Share Posted June 19, 2010 Then Martin should know to send you the bill for a purge valve:eyebrows: Unless of course the nitrous kit will just be for show/bragging rights:search: I don't use nos dude. Link to comment Share on other sites More sharing options...
