ray007 Posted June 19, 2010 Share Posted June 19, 2010 HI all I am about to replace my steering wheel with another stock one, before i mess anything up just wondering if anyone has done it before could provide a rough guide or advice on how to do so. Many thanks, any advice would be much appreciated Quote Link to comment Share on other sites More sharing options...
ronttuk Posted June 19, 2010 Share Posted June 19, 2010 I replaced my sterring whel a while back its easy, on mine i poped out the horn button removed the wire make sure it dont ground otherwise the horn goes off , undo the large nut under the horn button, with a sharp punch from behind it should come off, but be carefull it dont fly off and hit you in the face, Quote Link to comment Share on other sites More sharing options...
ray007 Posted June 19, 2010 Author Share Posted June 19, 2010 thanks bud, im on my out, let you know how i get on Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted June 19, 2010 Share Posted June 19, 2010 you may need a steering wheel pull but I modified a gear push clamp with some rope and it worked. Remember to use nut lock when putting the new wheel on. Quote Link to comment Share on other sites More sharing options...
nevins Posted June 19, 2010 Share Posted June 19, 2010 As above a simple job, if it it stuck, a couple of hits around the wheel and it will shock of the splines. Quote Link to comment Share on other sites More sharing options...
SupraHuman Posted June 19, 2010 Share Posted June 19, 2010 Don't undo the nut all the way before the wheel is loose, might save your pretty face. Quote Link to comment Share on other sites More sharing options...
