TT Paul Posted June 18, 2010 Share Posted June 18, 2010 window goes down on switch located passenger side but wont go up, drivers window works fine, but the switch on drivers side that operates passenger side window dosen't work at all, got 12v to switch on both wires checked motor working fine i know its not the window lock switch ANY IDEAS?? window has a bin bag over it need some help please:( Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 18, 2010 Share Posted June 18, 2010 See if you can get a switch or 2 to try. If the motor works and youre getting power its the logical choice. Get a battery and some wire, attatch it to the relevent pins in the plug to the motor to get the window up Quote Link to comment Share on other sites More sharing options...
TT Paul Posted June 20, 2010 Author Share Posted June 20, 2010 traced this fault took a while but got it.. theres 2 wires to the window motor, when you push switch one wire has 12v the 2nd is an earth, push switch other way the wires change so when switch is pushed it earts through the switch i found that one of the wires to the swith was broken put wire to earth up went the window. switch wires 2. earths 2. 12v feeds to motor, red, green/yellow strip 1. 12v feed to switch blue Quote Link to comment Share on other sites More sharing options...
