skyludeboy Posted June 18, 2010 Share Posted June 18, 2010 Im about to change my gearbox oil tommrow, just wanted to know the location of the filler plug for the gear oil or can it be filled from where the gear lever goes like on nissan 200sx's thanks Quote Link to comment Share on other sites More sharing options...
Guest westy99 Posted June 18, 2010 Share Posted June 18, 2010 The six speed box has a external linkage to the gearlever, the fill plug is on the side of the gearbox casing, hope this helps. Quote Link to comment Share on other sites More sharing options...
skyludeboy Posted June 18, 2010 Author Share Posted June 18, 2010 cheers will crack on with it tommrow, also by the way do I need a special tool to pump the fluid into the box or is there enough space to get a oil bottle on the side to fill the box up thanks again Quote Link to comment Share on other sites More sharing options...
Brazil Posted June 18, 2010 Share Posted June 18, 2010 I've read that ppl have used a funnel and hose, just feed a hose from the engine bay to the filler cap. Ps. Which oil are you using..? Make sure you put the right stuff Toyota's own V160 oil is what most recomend whiffbitz stocks it. Quote Link to comment Share on other sites More sharing options...
jevansio Posted June 18, 2010 Share Posted June 18, 2010 Filler is on passenger side, I just ran a pipe from it up beside the car & let gravity do the work. Prolly not enough room for a bottle Quote Link to comment Share on other sites More sharing options...
skyludeboy Posted June 18, 2010 Author Share Posted June 18, 2010 Thanks guys I brought some ATF oil from opie oils which they recommended to me so see how it goes Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted June 18, 2010 Share Posted June 18, 2010 ATF are you sure thats ok? I would stick to the proper stuff as i wouldn't fancy damaging a 6 speed box. Quote Link to comment Share on other sites More sharing options...
jevansio Posted June 18, 2010 Share Posted June 18, 2010 I used Royal Purple Synchromesh, no way I was paying Toyota £100 for 2 quarts, they're having your pants down Quote Link to comment Share on other sites More sharing options...
dude Posted June 18, 2010 Share Posted June 18, 2010 Getrag (who actually make the box) reccomend Dexron, the toyota stuff has always been and will be a rip off. I have a BRAND NEW 6 spd in my car and it has bog stock Dexron in it. Quote Link to comment Share on other sites More sharing options...
Terminator Posted June 18, 2010 Share Posted June 18, 2010 I am using Opie recommended oil too. Toyota are having a laugh. Quote Link to comment Share on other sites More sharing options...
Rinus Posted June 18, 2010 Share Posted June 18, 2010 Castrol transmax Z in my box... Quote Link to comment Share on other sites More sharing options...
skyludeboy Posted June 19, 2010 Author Share Posted June 19, 2010 The Oil I got from Opie Oils today is actually AMS OIL ATF UNIVERSAL AUTOMATIC TRANSMISSION FLUID, this was what was recommended to me but Im in 2 minds now about putting it in the gearbox now Quote Link to comment Share on other sites More sharing options...
Krister Posted June 21, 2010 Share Posted June 21, 2010 I used Royal Purple Synchromesh, no way I was paying Toyota £100 for 2 quarts, they're having your pants down Synchromax I hope? You shoudnt use synchromesh, it's not the correct type of oil. Quote Link to comment Share on other sites More sharing options...
jevansio Posted June 21, 2010 Share Posted June 21, 2010 Synchromax I hope? You shoudnt use synchromesh, it's not the correct type of oil. Sorry yeah smax, I always get them mixed up Quote Link to comment Share on other sites More sharing options...
