Lude Posted June 18, 2010 Share Posted June 18, 2010 guna be trimming my arch lips on the weekend, need a bit of sanding anyway as surface rust, and need a couple of mm taken off as tires rubbing. what shal i put on there to protect from rust? the car is white, hammerite then normal paint & laquer? Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 18, 2010 Share Posted June 18, 2010 just touch it up with paint mate, will be fine. can always underseal the arches whilst the wheels are off Quote Link to comment Share on other sites More sharing options...
evinX Posted June 18, 2010 Share Posted June 18, 2010 Mask the area that has the original paint, get some black hammerite for £6 from halfords, homebase or b&q, and paint behind the arch and the edge thats showing bare metal:) Quote Link to comment Share on other sites More sharing options...
Lude Posted June 18, 2010 Author Share Posted June 18, 2010 ok tidy. going to sand down the surface rust and spray with white (nobodys gona see/tell its there) the bits where i have cut with the grinder i think il put hammerite on. only come in black does it? Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted June 18, 2010 Share Posted June 18, 2010 subscribed Quote Link to comment Share on other sites More sharing options...
absz Posted June 18, 2010 Share Posted June 18, 2010 ok tidy. going to sand down the surface rust and spray with white (nobodys gona see/tell its there) the bits where i have cut with the grinder i think il put hammerite on. only come in black does it? you can buy hammerite in any colour, if grinding back to bare metal i would use some sort of primer first before painting to stop the rust re occuring or use a tin of underseal. Quote Link to comment Share on other sites More sharing options...
evinX Posted June 18, 2010 Share Posted June 18, 2010 ok tidy. going to sand down the surface rust and spray with white (nobodys gona see/tell its there) the bits where i have cut with the grinder i think il put hammerite on. only come in black does it? You can get any colour, they do the basics then you need to mix to get another, white is a normal one also for £6:) Quote Link to comment Share on other sites More sharing options...
Lude Posted June 18, 2010 Author Share Posted June 18, 2010 no need to primer it if just going to put hammerite on it? think its either hammerit on fresh metal, or primer, paint & laquer Quote Link to comment Share on other sites More sharing options...
evinX Posted June 18, 2010 Share Posted June 18, 2010 you can buy hammerite in any colour, if grinding back to bare metal i would use some sort of primer first before painting to stop the rust re occuring or use a tin of underseal. Hammerite is direct to bare metal it acts as primer, base and laquer:D great stuff im doing my whole supra hammerite satin black Quote Link to comment Share on other sites More sharing options...
Lude Posted June 18, 2010 Author Share Posted June 18, 2010 Hammerite Metal Paint™ is the quick and convenient way to protect and decorate metal surfaces. Unlike conventional systems, Hammerite Metal Paint™ can be painted directly onto rusty metal. Its special 3 in 1 formula means you do not need a primer or undercoat and it is touch dry in 1 hour. Hammerite Metal Paint™ also comes in a range of colours and finishes to match your specific requirements. Quote Link to comment Share on other sites More sharing options...
evinX Posted June 18, 2010 Share Posted June 18, 2010 Hammerite Metal Paint™ is the quick and convenient way to protect and decorate metal surfaces. Unlike conventional systems, Hammerite Metal Paint™ can be painted directly onto rusty metal. Its special 3 in 1 formula means you do not need a primer or undercoat and it is touch dry in 1 hour. Hammerite Metal Paint™ also comes in a range of colours and finishes to match your specific requirements. Damn right:D its good stuff, did my callipers in hammerite also:) Quote Link to comment Share on other sites More sharing options...
