Neil-NA Posted June 18, 2010 Share Posted June 18, 2010 I have a 95 2.0 petrol RAV4 thats done 88k miles, i noticed this morning that when starting it puffs out a little blue smoke for a second or so. Is this the valve stem seals? if so are they expensive to replace and is there any way of trying to prevent it getting any worse. Thanks. Quote Link to comment Share on other sites More sharing options...
R Black Posted June 18, 2010 Share Posted June 18, 2010 My girlfriend drives A RAV, it has smoked on start up for a couple of years now, yes I would say it is the valve stem seals, however its not a particularly cheap job hence we've not had it done, the vehicle is on a R plate and its not worth much so I don't see the point, it still runs fine. Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted June 18, 2010 Author Share Posted June 18, 2010 Yeah this runs fine and was only rof a second, was wondering if an oil change might help a bit, will see if it develops any further. Quote Link to comment Share on other sites More sharing options...
absz Posted June 18, 2010 Share Posted June 18, 2010 sounds like stem seals, being a old motor you can try a 10/40 semi oil instead of the recommended 5/30 and see how you get on. Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted June 18, 2010 Author Share Posted June 18, 2010 sounds like stem seals, being a old motor you can try a 10/40 semi oil instead of the recommended 5/30 and see how you get on. Cheers buddy, will give it a go. Quote Link to comment Share on other sites More sharing options...
