When changing/ordering the Oxygen sensors to N/A
FlrSupra
Ok.
Did some search on the forum I found excellent picture which showed me the location of Oxygen sensors in N/A. (good picture Nic, thanks).
Now I`m looking to order new sensors from Toyota. Is it enough just simply order the sensors and then just change them or do I need some harnesses or other stuff?
First time on this road so be gentle... :innocent:
The sensors come with the wire/plug connected, simply unplug the connector, remove the sensor, install new sensor and plug in!
If you struggle to find the second sensor plug, lift up the carpet in the drivers footwell and you should see it! :)
