Lap top with true serial port
Chris Wilson
It the battery requirement that is the difficult part as a new one is often more than 70 quid. Nearly all older laptops have nearly useless battery life. Does this bother you? Could you run off cigarette lighter in-cabin?
Make things easier for youself then if most cars dont have a fag lighter unit, get a old unit in a case, + and - wire which are fused with connectors that go to the battery of the car, then you can simply plug and unplug your laptop into their cars:D
I have an Ergo microlite xl.
It was my mums old laptop then used by my sister for a while with i think a hookie version of xp on it. Its just a laptop with charger.
Has a 1300mhz pentium processor and 248mb ram.
Not sure if the port it the one you need so check spec online if not I can post it to you and you can have a go then.
Unless anyone else knows how to check it? Never used a seriel port
