jackso11 Posted June 17, 2010 Share Posted June 17, 2010 My 1st decat has a boss with a sensor coming out of it that I think pligged into the standard temp sensor wires that were on the original cat. Can I just remove this and screw in an EGT probe sensor? or can I use the sensor that is already there and just wire it to an EGT guage? Dave, you might be able to answer this as you did my decat Quote Link to comment Share on other sites More sharing options...
absz Posted June 17, 2010 Share Posted June 17, 2010 its too far away from the turbo to give you a true reading. the closer to the turbo the better or in the exhaust manifold pre-turbo Quote Link to comment Share on other sites More sharing options...
jackso11 Posted June 17, 2010 Author Share Posted June 17, 2010 Dude says not to put it pre-turbo and just to put it in the downpipe or decat. Is this not an agreed placement? Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted June 17, 2010 Share Posted June 17, 2010 its too far away from the turbo to give you a true reading. the closer to the turbo the better or in the exhaust manifold pre-turbo I thought it was ok to put it in the decat & then add 200 degrees for the true reading? Quote Link to comment Share on other sites More sharing options...
absz Posted June 17, 2010 Share Posted June 17, 2010 I thought it was ok to put it in the decat & then add 200 degrees for the true reading? pre-turbo is normally the best option BUT if the sensor gets damaged then it more than likely damages the turbine blades. fitting the sensor in the downpipe and adding 200 degrees is just guess work ( in my opinion ) i had mine fitted to the turbo exhaust housing outlet side. Quote Link to comment Share on other sites More sharing options...
