DodgyRog Posted July 3, 2010 Share Posted July 3, 2010 Hi Darett, still have not got the bulbs and you have not let me know if they are in the post. If theres a problem, can you at least let me know Link to comment Share on other sites More sharing options...
a98pmalcolm Posted July 3, 2010 Share Posted July 3, 2010 my 10k's look awsome Link to comment Share on other sites More sharing options...
DARETT Posted July 3, 2010 Author Share Posted July 3, 2010 They're in the post Rog, I did PM you a couple of days ago. Glad your happy Paul Link to comment Share on other sites More sharing options...
DodgyRog Posted July 3, 2010 Share Posted July 3, 2010 They're in the post Rog, I did PM you a couple of days ago. Glad your happy Paul Thanks for the confirmation Darett, I only got a Pm saying you would check if they had gone in the post, but that they should of gone out already Thanks again, hopefully they will arrive Monday Link to comment Share on other sites More sharing options...
DARETT Posted July 3, 2010 Author Share Posted July 3, 2010 No probs dude, I'll get the tracking number off them on monday for you. Link to comment Share on other sites More sharing options...
neo2810 Posted July 4, 2010 Share Posted July 4, 2010 Thought I'd stick this pic from NOS's for sale thread (I'm sure he wont mind) which shows quite nicely the difference between the std yellow bulbs and HID's (at least I think the yellowy bulb is a normal, but it may be 4300's and 8000's ): Link to comment Share on other sites More sharing options...
mikeyh Posted July 4, 2010 Share Posted July 4, 2010 right guys im going to attempt to fit my hid's tomorrow are these just plug and play or is there more that needs doing apart from making a hole in the back of the bulb cover:search: Link to comment Share on other sites More sharing options...
monsween Posted July 4, 2010 Share Posted July 4, 2010 they are plug and play but you may have to bugger about with them swapping sides and turning connectors around. Link to comment Share on other sites More sharing options...
DARETT Posted July 5, 2010 Author Share Posted July 5, 2010 The easiest thing is to just look at the colour of the wires and match up the connectors. The plugs can be connected either way for different polarity applications, however if you check the colours prior there won't be any issues. Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 5, 2010 Share Posted July 5, 2010 Hi DARETT, I have my two sets I bought off you but wont be in a position to fit them for a few more weeks. Just for piece of mind I want to test them. Is there anyway to connect them to a 12v power supply to make sure they work? Link to comment Share on other sites More sharing options...
monsween Posted July 5, 2010 Share Posted July 5, 2010 Get someone to trundle round with their car and test them. Job done Link to comment Share on other sites More sharing options...
DARETT Posted July 5, 2010 Author Share Posted July 5, 2010 Lol, If you can't do the above; you can conjoin a wire from a 12v battery to the 9005/6 connectors, as an artificial power feed to test they're all working ok. Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 5, 2010 Share Posted July 5, 2010 will do. If i die by electrocution I'm coming back to haunt YOU! Link to comment Share on other sites More sharing options...
DARETT Posted July 5, 2010 Author Share Posted July 5, 2010 Lol, Wear rubber gloves!! JK, you should be fine, done it loads of times. The only time I got a bit of a shock was touching the unplugged wire from the ballast when the ballast had power going to it! Ouch, wasn't nice Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 5, 2010 Share Posted July 5, 2010 ok mate Will do. Oh, i always wear rubber gloves anyways,.. but thats for a totally different thread and forum. Link to comment Share on other sites More sharing options...
AndyJax Posted July 5, 2010 Share Posted July 5, 2010 PM'd yer Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 5, 2010 Share Posted July 5, 2010 Both kits seem to work fine. Handy hint to anyone installing. Try them first with a 12v Booster Jump starter. Took seconds to hook up and see the light colour. Link to comment Share on other sites More sharing options...
mikeyh Posted July 11, 2010 Share Posted July 11, 2010 mine all hooked up very easy kit to install thanks again:) Link to comment Share on other sites More sharing options...
monsween Posted July 11, 2010 Share Posted July 11, 2010 Received the ballast, will check it on a friends car as mine is away at th emoment fella Link to comment Share on other sites More sharing options...
Sakey Posted July 12, 2010 Share Posted July 12, 2010 Got them Can't fit them till next weekend though Link to comment Share on other sites More sharing options...
Guest blueangel Posted July 12, 2010 Share Posted July 12, 2010 can you find out what bulb i would need for gen 7 celica headlights dipped and main please but would need the supra fitment wiring. high and low beam if possible Link to comment Share on other sites More sharing options...
DARETT Posted July 12, 2010 Author Share Posted July 12, 2010 That can be arranged, just let us know when your ready. You'll need the H7 Bulb but 9005/6 Wiring. Link to comment Share on other sites More sharing options...
Sakey Posted July 18, 2010 Share Posted July 18, 2010 My ballast's hum when on, is this normal? Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 19, 2010 Share Posted July 19, 2010 what do they sing? - yes,... it normal Link to comment Share on other sites More sharing options...
neo2810 Posted July 25, 2010 Share Posted July 25, 2010 Hey darett my man, have u posted my 6k's yet? Link to comment Share on other sites More sharing options...
