Xenon HID Conversion Kits
DARETT
  • Replies 429
1. Wyntersun 4300k - HB4 (dipped beam UK spec lights) PAID AND SENT
2. Suprastar3000 6000k - HB3 x2 (Want both)PAID
3. adrianstokes 4300k - HB3 (dipped beam J-Spec lights)PAID
4. Arpus2010 6000k - HB3 (dipped J-spec)PAID AND SENT
5. Terminator 6000k Jspec Fogs PAID AND SENT
6. NOS 8000k - HB3. (can't add himself to group buys)
7. a98pmalcolm 10000k - HB3 -Jspec - (dipped and main also bulbs for fogs)
8. kill1308 -6000k - HB3 x 2 - Jspec (Would like dipped and high beam please) PAID
9. chp03bcd - 6000k - HB3 (J-Spec, dipped)
10. 3LL - 6000k HB3 ( Jspec, Dipped ) PAID
11. Spike3.0 - 8000k - HB3 (J Spec Dipped)
12. supra steveo - 6000K- J spec- dipped and foglights
13.mikeyh-6000k-(j spec-dipped) PAID
14.DodgyRog-6000k H7, 6000k HB4 -PAID
15. Sakey - 6000k-(j spec-dipped)
  monsween said:
Can I jump in on this or is it full? Jspec headlights.
Yup that's fine, just confirm which colour you want after payment is made.
  danger_supe said:
woohoo! at last!
please can i have a set of 8000k HB4 dipped beam for jspec supe with glass UK lights?
can pay with PayPal once you've confirmed this is ok
Cheers!
That's fine, they're in stock ready for delivery! :D
  DARETT said:
Which fog plug Imi?
I fitted into my J-spec fog's last year so can't really remember fully but can try.
Jspec lights, the fogs have a special lug that creates a water tight seal. most HID kits come with a universal plug that is different to the toyota one, so how do you go about securing it to seal properly.
Quite simply put you dont with kits ;)
Yup can indeed.
The H4 in single filament is the same price at £50 delivered.
You can also get it in a dual filament version (one bulb controls dipped and main beam via xenon) for £70 delivered...
Both types are in stock :)
2. Suprastar3000 6000k - HB3 x2 (Want both)PAID AND SENT
3. adrianstokes 4300k - HB3 (dipped beam J-Spec lights)PAID AND SENT
8. kill1308 -6000k - HB3 x 2 - Jspec (Would like dipped and high beam please) PAID AND SENT
9. chp03bcd - 6000k - HB3 (J-Spec, dipped) PAID NEED ADDRESS
10. 3LL - 6000k HB3 ( Jspec, Dipped ) PAID AND SENT
11. Spike3.0 - 8000k - HB3 (J Spec Dipped) PAID AND SENT
13.mikeyh-6000k-(j spec-dipped) PAID AND SENT
14.DodgyRog-6000k H7, 6000k HB4 -PAID AND SENT
16. Danger-Supe HB4 8K (UK Spec dipped) - PAID AND SENT
  Wyntersun said:
My Supra is Jspec with UK glass lights. The kit works fine. Fitted mine in about 20 mins. You will need HB4 bulbs for the uk glass lights. All the connectors from the HIDS fit the loom perfectly.
Great so how much each are they £50 so it would be £150 or £300
Quick few questions if I may.
I have jspec lights so I understand I need a set of H3 for dipped.
Q1: By main beam, I assume you mean the high beam you would use when theres no oncoming traffic on remote roads or to flash other drivers, and dipped would be the standard town driving lights?
Q2: If I wanted main beam, is there an option for dual filament on H3 (I see above H4 has that option for £70) or will I need a second set?
Q3: Since these run cooler than std lights, would this stop the yellowing you get on plastic jspec lights? If not, then I'll probably hold off until I've bought UK Glass headlights in a couple of months but if these solve the yellowing problem, then I'll just polish the lights just before installing HID's and stick with jspec.
Cheers in advance.
