a98pmalcolm Posted June 16, 2010 Share Posted June 16, 2010 Alpine MRP-M352 Digital Mono V-Power Amplifier Hi. Im selling an Alpine MRP-M352 Digital Mono V-Power Amplifier that is only 2 weeks old!! The amp is in perfect working order and the reason for the sale is a change in plans for my sound system set up. I was running this amp on a Rockford Fosgate 12" shallow punch sub and sounded fantastic! These amps retail at £149.99 and the bidding is starting at £79.99, and a buy it now at £99.99 Here is the spec list on the amp: * 1 Channel Operation * BassEngine® * Subsonic Filter * Bass EQ Circuit * Crossover (LP) * MOSFET Power Supply * DC-DC PWM Power Supply * Discrete Pre-Amp Stage * Double Buffered Pre-Amp Input Circuitry * STAR Circuitry * Top Mounted Blue LED Power/Status Indicator * Continuously Adjustable Gain Control * Speaker Level Inputs * Gold Plated Power Screw Terminals Gold Plated Speaker Terminals * Cross-Vented Chassis Design CEA-2006 Power Rating * CEA-2006 Power Rating (40hm at 14.4V = 1%THD+N), S/N 60dBA (Ref. 1W into 4Ohm): 200x1 RMS Power (at 14.4V THD+N, 20Hz-200Hz) * Per channel into 4 ohms: 200W x 1 (1.0% THD) * Per channel into 2 ohms: 350W x 1 (1.0%) * Total Max. Power: 700W BassEngine® Sound Tuning * Crossover Network: 18dB/oct * Low Pass Crossover Frequency (Adjustable): 50Hz – 200 Hz * Subsonic Filter (Fixed): 15Hz @ 24dB/oct. * Bass EQ Frequency (Fixed): 50Hz * Bass EQ Level (Adjustable): 0 - 12dB General * Power Requirements: 14.4V DC (11V to 16V) * Frequency Response: 20Hz – 200kHz (+0, -3dB) * Signal to Noise (S/N): 90dBA (referenced to rated power) * Input Sensitivity (For Rated Power): 0.2V to 4.0V * Input Impedance: 10k Ohm * Speaker Impedance: 4 or 2 Ohm (Stereo) * Dimensions (WxHxD): 199mm x 60mm x 267mm * Dimensions (WxHxD): 7-4/5" x 2-2/5" x 10-1/2" * Weight: 2.52 Kg. (5 lbs. 9 oz) Any questions feel free to ask Thanks for looing Paul Ebay Link: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160446045736&ssPageName=STRK:MESELX:IT http://img252.imageshack.us/img252/7132/20100616002.jpg Link to comment Share on other sites More sharing options...
