difference!!
Guest damo1
Guest damo1
rite lads the time is coming soon to order my motor but whats the difference between the aero-tops and normal supra's i mean maintance wise is there any negatives to them. as im looking to get a black aero-top tt or single turbo but need the info first b4 i jump in the deep end so to speak
cheers boys..
the main difference is the roof comes off the aero top , on the hard top it dosent :p
mechanicly they are the same . same parts ect
if you want a tt aero you will have to do it yourself or find one that has already been converted as all the rhd were na auto from the factory.
Don't think that's quite right. There are TT Aerotops but they're all auto. I think:)
I always used vaseline and some rubber lubricant to sort out the tbar on my mr2, i'm sure it's just the rubber seals that perish over time, most probably replaceable if you get a leaky one.
EDIT: Michael is right, don't use vaseline, i was thinking of other things :D
Edited by Dave17 (see edit history)
Vaseline will rot the rubbers, it's petroleum based, better to use a silicone lubricant for rubber.
cheers boys..
My advice is to lose the text speak, slip in the odd comer and full stop and i might take time to answer your questions.
You have been warned loads of times, i wont be surprised if you get a ban soon.
i see a future MOD in the making:D
Guest damo1
Aerotops get very expensive to run if you're in the habit of popping the roof off going down the motorway a la how NOS would probably like to :)
funny as!! with regards to txt talk that was my 1st mistake in over a week and half so i think i deserve a pat on the back.....
no i think im going to be sticking with the normal supra tt or single...
speaking of which has anyone on here bought a single turbo supra from japan and how much if you dont mind me asking
