Rear Brake Discs issue
dani_r
My rear brake discs have a line around the outer edge that looks like the pad isn't touching the disc. It's creating a line of rust similar to what you might expect to see if you hadn't used your brakes for a while!
Any ideas? I'm supposed to be going away next week to the UK with the car :(
It's normally nothing to worry about, as it is where the pad isn't touching the disc. It happens as the disc wears. You have to be careful that the corrosion isn't TOO bad though, and that the discs are still thick enough.
