JakeG Posted June 16, 2010 Share Posted June 16, 2010 I got my trial rear sprayed and fitted finally, but now im having trouble with the heat of the exhaust, its getting so hot the paint on the soround for the exhaust is bubbling, any have this problem and any solutions? Quote Link to comment Share on other sites More sharing options...
Blackie Posted June 16, 2010 Share Posted June 16, 2010 same problem i had, If you look to the right of the pipe there is a tow eye thing on the chasis of the car, I got a fat grip tie and pulled it across away from the edge of the bumper. Quote Link to comment Share on other sites More sharing options...
JakeG Posted June 16, 2010 Author Share Posted June 16, 2010 I actually done the same thing with a huge cable tie, it seems to be the length of the exhaust on mine as if it's too short r something Quote Link to comment Share on other sites More sharing options...
Blackie Posted June 16, 2010 Share Posted June 16, 2010 Same here chap, You can get them sleved (sp) to make make them longer to clear the bumper Quote Link to comment Share on other sites More sharing options...
JakeG Posted June 16, 2010 Author Share Posted June 16, 2010 will hada look into that one then, dont want my good paint job ruined lol cheers for the help mate! Quote Link to comment Share on other sites More sharing options...
Blackie Posted June 16, 2010 Share Posted June 16, 2010 will hada look into that one then, dont want my good paint job ruined lol cheers for the help mate! No problem Quote Link to comment Share on other sites More sharing options...
Stephen G Posted June 16, 2010 Share Posted June 16, 2010 is that a motorola or something like that exhaust, if so mine would sit a bit shy from the oem back bumper was spot on when the cats was on the car but the decat pipe i got must been a little bit shorter, i'm just going to get someone who works with stainless steel to cut it and put a inch into it or so Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 16, 2010 Share Posted June 16, 2010 Your tailpipe is to short, cut it off and weld on a longer one. Quote Link to comment Share on other sites More sharing options...
evinX Posted June 16, 2010 Share Posted June 16, 2010 Should always use heat resistant paint on diffusers, but then again stock bumpers and aftermarket exhausts dont get this problem Quote Link to comment Share on other sites More sharing options...
