skyludeboy Posted June 15, 2010 Share Posted June 15, 2010 when cold I get up to 6.5-7 bar pressure when warm I get 3 bar pressure when flooring it redline I get 9 to 9.5 bar oil pressure I have blitz gauge with sensor connected to sandwich plate, are my figures a bit too high? will I have problems in the long run, Im using silkolene 10w50 oil thanks Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 15, 2010 Share Posted June 15, 2010 Sounds high to me, but I would only trust a mechanical gauge, not a cheaply produced aftermarket electronic one. Get a garage to fit a calibrated master gauge and see if the readings are the same. 10 bar is getting to ruptured oil filter canister territory. Quote Link to comment Share on other sites More sharing options...
skyludeboy Posted June 15, 2010 Author Share Posted June 15, 2010 sorry just done a few more readings i can now confirm that it hits 8.5 bar max oil pressure on full chat is this acceptable? what mods can i do to make the pressure come down? Quote Link to comment Share on other sites More sharing options...
dude Posted June 15, 2010 Share Posted June 15, 2010 If you measure at the block you will find it is a lot lower, I personally think the sandwich plate somehow inflates the oil pres reading, I told Titan I was getting the same sort of figures at the same place and they did not think it was a problem. In fact they remove the stock cooler and bolt the filter straight to the block to increase pressure. Quote Link to comment Share on other sites More sharing options...
