Nodalmighty Posted September 21, 2012 Share Posted September 21, 2012 I can free up a port on the Syvecs as the ECU doesn't really need to know about oil temp Lyndon. Lyndon, Now that'll do nicely! But I emailed Larry at SP and he wouldn't say it was 100% bulletproof for this application...He did say it is a **must** to have a good ecu controlling any new autobox though - and a full strength 2nd gear sprag. So be interested to see how much we can tweak the Syvecs S6 for this - I think I've run out of spare ports on it though... Link to comment Share on other sites More sharing options...
GlennK Posted September 21, 2012 Author Share Posted September 21, 2012 I can free up a port on the Syvecs as the ECU doesn't really need to know about oil temp Lyndon. Great. Thanks Lyndon. So you will take the oil temp feed straight off the sensor and feed it into your new OLED display controller? Link to comment Share on other sites More sharing options...
Luxluc Posted September 21, 2012 Share Posted September 21, 2012 What about a sequential box Glenn?? Link to comment Share on other sites More sharing options...
GlennK Posted September 21, 2012 Author Share Posted September 21, 2012 What about a sequential box Glenn?? Well, if I had $12000 to throw at the problem then yes! Link to comment Share on other sites More sharing options...
Luxluc Posted September 21, 2012 Share Posted September 21, 2012 Why not go manual? Link to comment Share on other sites More sharing options...
GlennK Posted September 22, 2012 Author Share Posted September 22, 2012 1. Cannot get anywhere near the ultrafast auto gear changes. After 1st to 2nd its not noticed - with foot flat down. 2. Around £6k for a good conversion Link to comment Share on other sites More sharing options...
bignum Posted September 22, 2012 Share Posted September 22, 2012 1. Cannot get anywhere near the ultrafast auto gear changes. After 1st to 2nd its not noticed - with foot flat down. 2. Around £6k for a good conversion You can have mine for 5999:) Link to comment Share on other sites More sharing options...
Luxluc Posted September 22, 2012 Share Posted September 22, 2012 You can have mine for 5999:) - - - Updated - - - 1. Cannot get anywhere near the ultrafast auto gear changes. You need to train manual shifting Link to comment Share on other sites More sharing options...
GlennK Posted October 9, 2012 Author Share Posted October 9, 2012 Luc, I'm getting an SRD Staqe 4 custom built autobox. Details of what this is in the SRD thread... Link to comment Share on other sites More sharing options...
Luxluc Posted October 10, 2012 Share Posted October 10, 2012 Nice Glenn. When will it be ready for fitting? Link to comment Share on other sites More sharing options...
GlennK Posted October 10, 2012 Author Share Posted October 10, 2012 As soon as Lee can get it done! Link to comment Share on other sites More sharing options...
GlennK Posted March 6, 2013 Author Share Posted March 6, 2013 **Update** Had a good mapping session yesterday at SRR. Ran it to 650bhp/600ftlbs at 1.8bar. Then swapped to a 4bar MAP sensor and remapped. Took it to 1.95bar boost and the engine was running sweet - and the new SRD Stage 4 autobox was perfect . BUT didn't get a conclusive set of numbers as the tyres lost traction. All I can say is the road test left a big smile on my face. Now a rough calculation says 1/9th more boost (at 2bar) should give a 1/9th more power. That means it is showing around 710bhp and 650ftlbs. Which feels about right TBH. And SRR calculates on a manual box so the figures for the autobox are on the conservative side... Anyhow the car is set up with the S366 pushed to its limit and holding boost all the way up. Impressive fast spooling street turbo. Thinking of a larger one now... And need to get bigger rears - ideally 305s on my 18" rims. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 6, 2013 Share Posted March 6, 2013 **Update** Had a good mapping session yesterday at SRR. Ran it to 650bhp/600ftlbs at 1.8bar. Then swapped to a 4bar MAP sensor and remapped. Took it to 1.95bar boost and the engine was running sweet - and the new SRD Stage 4 autobox was perfect . BUT didn't get a conclusive set of numbers as the tyres lost traction. All I can say is the road test left a big smile on my face. Now a rough calculation says 1/9th more boost (at 2bar) should give a 1/9th more power. That means it is showing around 710bhp and 650ftlbs. Which feels about right TBH. And SRR calculates on a manual box so the figures for the autobox are on the conservative side... Anyhow the car is set up with the S366 pushed to its limit and holding boost all the way up. Impressive fast spooling street turbo. Thinking of a larger one now... And need to get bigger rears - ideally 305s on my 18" rims. Sounds good Glenn, have you seen my billet upgrades for the Borg Warner turbos? Link to comment Share on other sites More sharing options...
GlennK Posted March 6, 2013 Author Share Posted March 6, 2013 Paul, I have seen the new Bullseye series but not the billet upgrades... Link to comment Share on other sites More sharing options...
Luxluc Posted March 7, 2013 Share Posted March 7, 2013 (edited) Wow Glenn. That sounds very impressive. Are you still on 264 cams? Edited March 7, 2013 by Luxluc (see edit history) Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 7, 2013 Share Posted March 7, 2013 **Update** Had a good mapping session yesterday at SRR. Ran it to 650bhp/600ftlbs at 1.8bar. Then swapped to a 4bar MAP sensor and remapped. Took it to 1.95bar boost and the engine was running sweet - and the new SRD Stage 4 autobox was perfect . BUT didn't get a conclusive set of numbers as the tyres lost traction. All I can say is the road test left a big smile on my face. Now a rough calculation says 1/9th more boost (at 2bar) should give a 1/9th more power. That means it is showing around 710bhp and 650ftlbs. Which feels about right TBH. And SRR calculates on a manual box so the figures for the autobox are on the conservative side... Anyhow the car is set up with the S366 pushed to its limit and holding boost all the way up. Impressive fast spooling street turbo. Thinking of a larger one now... And need to get bigger rears - ideally 305s on my 18" rims. Thats an amazing result. Glad to read about the box being good and taking the power. Thats next on my shopping list but got to save up for that. Get some vids Link to comment Share on other sites More sharing options...
GlennK Posted March 7, 2013 Author Share Posted March 7, 2013 Wow Glenn. That sound very impressive. Are you still on 264 cams? Hi Luc, Yep. 264/264. And I see you are trying out the new BW billet upgrade. What's the performance improvement like? Link to comment Share on other sites More sharing options...
GlennK Posted March 7, 2013 Author Share Posted March 7, 2013 Thats an amazing result. Glad to read about the box being good and taking the power. Thats next on my shopping list but got to save up for that. Get some vids Will do Rob! Link to comment Share on other sites More sharing options...
Luxluc Posted March 7, 2013 Share Posted March 7, 2013 Hi Luc, Yep. 264/264. And I see you are trying out the new BW billet upgrade. What's the performance improvement like? Oh yes. The engine will be re-assembled next week. Then comes the running in time, and mapping beginning of April. I'm looking to come (with the new BL 366 turbo) as close as possible to 900 bhp. Link to comment Share on other sites More sharing options...
Chris Bailey Posted March 10, 2013 Share Posted March 10, 2013 Vidoes Link to comment Share on other sites More sharing options...
Luxluc Posted September 11, 2013 Share Posted September 11, 2013 How is your beast running mate. Any updates? Link to comment Share on other sites More sharing options...
GlennK Posted September 12, 2013 Author Share Posted September 12, 2013 Hi Luc, it was running ok but I had to replace the EGT probe as the readings were all over the place. Seems ok now. The new SRD custom built autobox continues to impress. Solid performance and gear changes. Would love to know what torque it can handle... But I haven't had an opportunity to get it hub dyno'd this year. So a still do not know what its power figures are. On high boost it feels like it will take off Link to comment Share on other sites More sharing options...
Luxluc Posted September 12, 2013 Share Posted September 12, 2013 I was at SRR 2 weeks ago .. totally forgot to drop you a text to meet you and your Supra. Link to comment Share on other sites More sharing options...
GlennK Posted September 12, 2013 Author Share Posted September 12, 2013 Next time then...what were the results of your SRR dyno? I want to try a hub dyno soon to see what improvements the inlet and exhaust and autobox mods I made over the year have given. I found my old SRR dyno graph from the run last September: Link to comment Share on other sites More sharing options...
Luxluc Posted September 12, 2013 Share Posted September 12, 2013 I wasn't on the rollers mate ... only met Ryan for some adjustments (got the latest Syvecs software, some fine tuning at idle and low revs to have it more streetable) and the setting up of the Toucan will all the sensors and alarms. My Michelin semi-slick tires are rubbish for the rollers, as they will heat up too much and slip. I will stick to the hub dynos. I had a chat with Charlie, and he guessed 750 at the hubs should be around 820-830 bhp. I won't give it a try though...it pulls really hard from 4000 to the 8k rev limiter. Link to comment Share on other sites More sharing options...
