Luxluc Posted September 3, 2012 Share Posted September 3, 2012 So you think 2 bar should max the turbo out with a good built engine Mark? Link to comment Share on other sites More sharing options...
mark newman Posted September 3, 2012 Share Posted September 3, 2012 mybe but this is with a 3'' exhaust . if you fit a 4'' you might get more 2.2 bar would be nice . Link to comment Share on other sites More sharing options...
Luxluc Posted September 3, 2012 Share Posted September 3, 2012 I'm still undecided to go for 4" DP/MP combo, or to stick with my 3" DP/MP. I have fitted the 4" Whifbitz Ti exhaust, which is more free flowing than the Dragger I had before. I'm not sure if a 4" DP/MP is really necessary on such a small turbo which comes with 3" flange. Link to comment Share on other sites More sharing options...
mark newman Posted September 3, 2012 Share Posted September 3, 2012 I think it would be better with more flow. I fitted a 4'' back onto mine two weeks ago and i found that made some gain so all the way got to be better, if i was going to keep this set up I would be going 4'' all the way the cost to do this is only £250 and £about £60 for the 4-3 v band , I think its a win win. Link to comment Share on other sites More sharing options...
Luxluc Posted September 3, 2012 Share Posted September 3, 2012 You're probably right ... I'll think about it, as I still have time before the engine comes out. Cheer Luc P.S. Sorry Glenn for hijacking your thread Link to comment Share on other sites More sharing options...
mark newman Posted September 3, 2012 Share Posted September 3, 2012 If you want to break the record Link to comment Share on other sites More sharing options...
Luxluc Posted September 3, 2012 Share Posted September 3, 2012 If you want to break the record Link to comment Share on other sites More sharing options...
GlennK Posted September 3, 2012 Author Share Posted September 3, 2012 That's ok - intetesting Mark - only £310 for the DP/MP and adapter then...I'll see what happens at SRR next week! Link to comment Share on other sites More sharing options...
Luxluc Posted September 4, 2012 Share Posted September 4, 2012 When will you be on the rollers next week mate? Yes, around 300£ for going full 4" sounds interesting. Good luck Glenn. Link to comment Share on other sites More sharing options...
GlennK Posted September 4, 2012 Author Share Posted September 4, 2012 Next Monday 10th in the morning. There's a few others being done too. Coming over Luc? Link to comment Share on other sites More sharing options...
Luxluc Posted September 4, 2012 Share Posted September 4, 2012 No ... I'm just curious. Cheers Luc Link to comment Share on other sites More sharing options...
GlennK Posted September 11, 2012 Author Share Posted September 11, 2012 Luc, It made 678hp at 1.6bar...with a wastegate problem. Fixed that and the turbo went to 2.6bar... Only problem is that the inlet IC plastic pipe split. So had to adjourn the mapping session Lee will fix up then back to SRR soon as and Ryan will fit a 4 bar MAP sensor and we'll go for 2.1 bar and see where it gets to... Link to comment Share on other sites More sharing options...
Parry_10 Posted September 11, 2012 Share Posted September 11, 2012 very nice Glenn Link to comment Share on other sites More sharing options...
Luxluc Posted September 11, 2012 Share Posted September 11, 2012 Wow Glenn. That's a nice result. What cams are you on for the moment? When is the next session planned? Link to comment Share on other sites More sharing options...
GlennK Posted September 11, 2012 Author Share Posted September 11, 2012 I'm running Whifbitz 264/264 at the moment. Just as soon as I can get the new pipe in and get a slot in Ryan's diary before Friday!!! (I'm off to be a spectator at the Ferrari Days at Silverstone at the weekend so must have the engine at 110% ) Dropping car at Lee's this evening... Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted September 11, 2012 Share Posted September 11, 2012 I'm running Whifbitz 264/264 at the moment. Just as soon as I can get the new pipe in and get a slot in Ryan's diary before Friday!!! (I'm off to be a spectator at the Ferrari Days at Silverstone at the weekend so must have the engine at 110% ) Dropping car at Lee's this evening... Oooo is that on the Sat or Sunday mate as i'm only 5 mins from Silverstone so might pop up and have a sneaky peak Link to comment Share on other sites More sharing options...
GlennK Posted September 11, 2012 Author Share Posted September 11, 2012 Yep. That's on from Friday through to Sunday. Likely I'll be going on Sunday. Link to comment Share on other sites More sharing options...
Luxluc Posted September 11, 2012 Share Posted September 11, 2012 I keep the fingers crossed for you Glenn. 2.1 bar will give you an awesome figure ... 0.5 bar more should give you an additional 60 bhp. Can't wait for the new figures ... and don't forget to kick some a*** on Sunday with those horse-cars Link to comment Share on other sites More sharing options...
Luxluc Posted September 11, 2012 Share Posted September 11, 2012 By the way Glenn. What was the torque figure at 1.6 bar? Link to comment Share on other sites More sharing options...
GlennK Posted September 11, 2012 Author Share Posted September 11, 2012 Didn't get the printout of it but from memory it was near the hp figure ie in the 600's. When Ryan gets that mapping finished with those kind of numbers then those horses are going to look more like donkeys Link to comment Share on other sites More sharing options...
Luxluc Posted September 11, 2012 Share Posted September 11, 2012 Were the 678 flywheel calculation? Link to comment Share on other sites More sharing options...
GlennK Posted September 11, 2012 Author Share Posted September 11, 2012 Yep. Using the manual box calculations...so it is actually somewhat more than that Link to comment Share on other sites More sharing options...
Luxluc Posted September 11, 2012 Share Posted September 11, 2012 Ah yeah ... I forgot you don't do it yourself. Tell Ryan to beat the s*** out of that little 66mm tubbie Link to comment Share on other sites More sharing options...
GlennK Posted September 11, 2012 Author Share Posted September 11, 2012 Well, some of us are just too lazy to use our own hands O:-) Ryan's already got that tubbie's card marked. He'll make it scream ;-) Should get the car back tomorrow evening from Lee's. Keep you updated here. Link to comment Share on other sites More sharing options...
Luxluc Posted September 14, 2012 Share Posted September 14, 2012 What's the status on the car Glenn? Have you fixed the pipe and put the new map sensor in? Link to comment Share on other sites More sharing options...
