BW91/79 Single Project
GlennK
  • Replies 232
blimey mate that is HUGE!!
how much do those manifolds go for ??
must feel like an animal on the road :D
Twingate manifold on its own is about £1200 + VAT. Then you need 2 wastegates, on Glenns car we used 2x Tial 38mm MVS as they are so small and makes it easier to fit everything in, about £220 each + VAT. You'll then need to make a downpipe to fit it. I'm thinking about producing it as a kit now after this result has backed up the result I had on my car.
interesting, cheers Paul sounds like a good route :)
Do it!
Just finished at SRR this afternoon. Ryan tuned my traction control via the Syvecs. And perfect weather conditions too! Slight drizzle, glistening roads. In 1st position 'Low Boost (0.9b), Wet Road' gave it WOT from rolling start.
Some back end shimmy when the power hit.
/vbb/images/smilies/bbcode_shock.gif
Ryan tweaked a bit more. Then a second run. Better. Then a final tweak and floored it hard. Straight as a die!! No instability at all. Retried. Same. Rock solid road holding. No wheelspin. No skipping. Incredible.
A big Thank You to Ryan again for his expert tuning down the zero tolerance perfection point!!:D
P.S. Paul - Good Luck with your GT4094R tuning session this afternoon. And get those slicks swapped for tyres that don't slip off the rolling road :)
