Excel help!
tbourner
Is it possible to auto arrange something in excel or do you have to manually do it? I know there are several ways to do it manually but ideally what I want is column A to have numbers in, and I want to somehow be able to change the numbers in column A (whether manually typing or with drop down menus or something) and it update the rest of the numbers in column A so there's no duplicates, and re-order them in descending order with the remaining columns moving as well.
Like an auto data-sort kind of thing?
Yeah it's possible. I have our footy spreadsheet doing an auto sorting leaderboard thing, based on data from elsewhere on the sheet. I don't have time to explain in detail at the mo but I could attach it if you want a look at it?
Thanks mate, it's a bit of a roundabout way of doing it for what I want though. I could have a seperate table with the info in and do lookups to that for the 'display' table, but I'd need to adjust the figures on the data table which then wouldn't be in order (if that makes sense).
Basically, for my use; it would be easier to just grab the table and sort each time, I was just wondering if there was some command or function that could do it easily.
