Is my engine dead?
Suprab1
Hi lads, i have a petrol lawnmore & lastyear it was reving high when started for about 5 secs then it would settle. The last time it was used i was cutting the grass & it reved high for about 5 secs (uaually would only do this when starting it) then cut out. I had forgot about it until i went to use it today & it wouldn't start. I checked for a spark, put in fresh petrol & checked oil. Is there something i'm missing or has it just died?
They can be fun to get goin at the start of the season, can't they!
Probably just some crud in the carb Rab.
Have you checked to see if the plug is wet after you attempt to start it a few times?
Sometimes a fresh plug will get the S.O.B. going
The best thing to do is strip it and clean it if you know what you are doing.
If not bring it to someone who does know and get it serviced.
Cool ;). I might strip it myself i like to get my hands dirty lol. I will work it out when its in bits, sure i can't make it any worse. At least i'll have tried.
How did your track day go Damien?
Good man, I like to see blind faith in one's own abilities!:D
The track day went great. Met some nice people and we raised a nice bit of cash for the chaity. I drove it like I stole it for the hour I had it out on the track. Brought my sister, my partner and her brother out for a few laps, mostly sideways! They all loved it.
I've a few snaps of the day in the multimedia section.
check the governor spring isn't broken. This happened to out Briggs and Stratton engine last year. Revved really high and smoked until the engine cut out. Found out the governor spring had broken.
What is that? & where about is it?
Sounds like you had a great time. You've me wanting a track car now lol.
I hope to see you sometime out on the track, its not very often you see supras on the track over here.
I'll be out on the track again on the 30th of July.
A full day on the International Circuit at Mondello with a BBQ going all day to keep us fed! All for €200.
Come on up if you aint doing anything, even for an hour.
Heat the plug up in the oven;)
First start of the season is always a real PITA, give the spark a good clean ;)
Thanks lads i will try these tomorrow ;)
I might do that. I would only be a spectator though as i don't fancy killing my pride & joy lol.
