robsaxby Posted June 13, 2010 Author Share Posted June 13, 2010 Id say the pump is dead. Ive got a spare pump if you want to try it what pump is it mate, standard one or an upgrade. if i find out that the fuel pump is dead, then ye pal, cheers Quote Link to comment Share on other sites More sharing options...
scotty71 Posted June 13, 2010 Share Posted June 13, 2010 Is it still firing up or intermitant? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 13, 2010 Share Posted June 13, 2010 No its standard Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 13, 2010 Author Share Posted June 13, 2010 still firing up, gona leave it for awhile and try again, go for a blast in it, see how it performs Quote Link to comment Share on other sites More sharing options...
jagman Posted June 13, 2010 Share Posted June 13, 2010 Voltages can be checked off load or on load- if the pump is disconnected it's off load - so you would get battery voltage, if not exactly battery voltage then a connection problem If voltage on load (pump connected) then the voltage can drop a bit , but too much means the pump is knackered - dragging down the volts or filter blocked , making the pump work harder Y ou can use a bulb and 2 pieces of wire to simulate on load ( if bulbs big enough) and check if the bulb dims compared to straight across the battery Quote Link to comment Share on other sites More sharing options...
