robsaxby Posted June 12, 2010 Share Posted June 12, 2010 help guys, iv been out in car today, running fine, started perfect this morning, been home, went to go start it, and nothing, all my lights work, everything spins but just not firing, fuel pump problem? also wen the key is turned, the fuel pump doesnt prime and there is no noise from the pump itself, u knw the buzzing sound? there is a hks fuel and ignition timing computor in the passenger footwell, not sure if it has been knocked any help would be brilliant, cheers Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 12, 2010 Share Posted June 12, 2010 Try the fuel pump bypass mate, that should rule the pump ECU out. Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 12, 2010 Author Share Posted June 12, 2010 bypass?? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 12, 2010 Share Posted June 12, 2010 Have a search, get a paperclip, open the engine bay diagnostic port insert the clip into the port FP and...... Im not sure of the other and I dont want to say maybe incase it wrecks something... *edit, you do this to get round the fuel pump ECU, if its shagged the fuel pump wont run * Quote Link to comment Share on other sites More sharing options...
scotty71 Posted June 12, 2010 Share Posted June 12, 2010 (edited) found it...... +B to FP connections of the diagnostic port on the engine (i.e. voltage fed to the pump all the time the ignition is on). But Rob.. All the time this advice has been given its on a (do it on your own head basis) As swampy said. Dont shag up your nice TT 6spd matey before you ask The diag port is on the front of intake plenum, it has should have diag written on it Edited June 12, 2010 by scotty71 (see edit history) Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 12, 2010 Share Posted June 12, 2010 Easiest way to check the fuel pump would be to run a piece of hose directly off of it and into a bucket or the ground if your lazy and then turn the engine over. Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 12, 2010 Share Posted June 12, 2010 *edit, you do this to get round the fuel pump ECU, if its shagged the fuel pump wont run * Only for testing though, don't run it full time this way, the diag wiring loom is not up to long term high current. The FP diag port is for reading the voltage going to pump, not for supplying it. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted June 12, 2010 Share Posted June 12, 2010 I have just rang Rob after the diag port post and told him this is for TESTING ONLY He's only had it a week.... seen it last night, nice white TT 6spd Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 12, 2010 Author Share Posted June 12, 2010 cheers lads for the bypass method, tried it, but got nothin, no prime no buzz no go !! Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 12, 2010 Share Posted June 12, 2010 Okay, go back to basics... Have you got a voltmeter? Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 12, 2010 Author Share Posted June 12, 2010 haha, one thing i need, and i aint got one Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 12, 2010 Share Posted June 12, 2010 Get down to maplins and get one, they aren't expensive and will make tracing a lot easier Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 12, 2010 Author Share Posted June 12, 2010 haha ye wil do pal, we can go from there then, cheers Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 12, 2010 Share Posted June 12, 2010 Start checking voltages from the fuel pump back, the fuel circuit is a fairly simply system. Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 12, 2010 Author Share Posted June 12, 2010 cheers mate, il get on it wen iv bort a voltmeter haha cheers again Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 13, 2010 Author Share Posted June 13, 2010 Day 2 on the fuel pump, got my volt meter Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 13, 2010 Author Share Posted June 13, 2010 seems to be power going to fuel pump ecu and the pump itself, but no prime still Quote Link to comment Share on other sites More sharing options...
scotty71 Posted June 13, 2010 Share Posted June 13, 2010 how much power? Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 13, 2010 Author Share Posted June 13, 2010 power going to fuel pump ecu, is 11.6 and power going to fuel pump itself, goes from 5 up to 11 depending which connects you pick, bt there is definitly power going to pump Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 13, 2010 Author Share Posted June 13, 2010 guys its started, dnt no y, but just been in passenger footwell, having a look and making sure everything connected, jst tried it fire up Quote Link to comment Share on other sites More sharing options...
Steve Posted June 13, 2010 Share Posted June 13, 2010 I would be checking all your connections then in the footwell. Quote Link to comment Share on other sites More sharing options...
jagman Posted June 13, 2010 Share Posted June 13, 2010 Sounds like you need a new pump and filter Quote Link to comment Share on other sites More sharing options...
scotty71 Posted June 13, 2010 Share Posted June 13, 2010 with having power to the ECU/pump I think someone has caught the HKS gizmo in the footwell thus creating a loose connection. As you have just stated...check all the connections to the HKS so it is definate.. dont want it to conk out on you miles from home Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 13, 2010 Share Posted June 13, 2010 Id say the pump is dead. Ive got a spare pump if you want to try it Quote Link to comment Share on other sites More sharing options...
robsaxby Posted June 13, 2010 Author Share Posted June 13, 2010 fuel filter is a good call mate, i have left it running for abit and turned it off, and it started again first, reali strange, loose connection possibly or fuel filter Quote Link to comment Share on other sites More sharing options...
