Robby Posted June 12, 2010 Share Posted June 12, 2010 I have hunted high and low for this answer but can't seem to find it, only bits and bobs! Hope someone can answer this! What is the legality of decating my TT import? Would it invalidate my insurance should I be involved in an accident? Thanks! Quote Link to comment Share on other sites More sharing options...
Guest damo1 Posted June 12, 2010 Share Posted June 12, 2010 anycar after 1993 Kplate must be fitted with an cat but with your car being an import it may change if i was you go to your local mot station and ask if still not happy get your self a sports cat.... Quote Link to comment Share on other sites More sharing options...
hiten55 Posted June 12, 2010 Share Posted June 12, 2010 As long as it passes mot and you have told the insurance company its been de-cated theres no problem. you could always remove both and place the 2nd one back in for the mot Quote Link to comment Share on other sites More sharing options...
Branners Posted June 12, 2010 Share Posted June 12, 2010 You certainly need to tell the insurance company. A decat massively improves the performance of the car so it is something the insurance company certainly need to know about. The car will probably need a cat to pass an MOT, you could try the arguement that the car is not in their database but I have not heard of that working many times. Do be aware your car could be roadside tested for emissions and found to be illegal without a cat. They will issue a rectification notice (or might even impound the car if being awkward) so you would need to get an MOT to prove the car has cats fitted. But that happens extremely rarely. Quote Link to comment Share on other sites More sharing options...
Paul Posted June 12, 2010 Share Posted June 12, 2010 As far as insurance goes wouldn't it come under 'modified exhaust' ? Quote Link to comment Share on other sites More sharing options...
Pete Posted June 12, 2010 Share Posted June 12, 2010 As far as insurance goes wouldn't it come under 'modified exhaust' ? Depends on the insurer. I've had ones list it explicitly and others stick it down as you suggest. As long as you tell them in your own words then you should be ok but obviously come to the law then you should record that conversation. Quote Link to comment Share on other sites More sharing options...
monsween Posted June 12, 2010 Share Posted June 12, 2010 Declare it as a de-cat and leave it up to your insurance company with regards to classfication. You may get an increase in premium but worth it if things go wrong. Quote Link to comment Share on other sites More sharing options...
