djg99 Posted June 1, 2005 Share Posted June 1, 2005 can anyone tell me how easy it is to take the rear wing off , and how do to it? Quote Link to comment Share on other sites More sharing options...
Nic Posted June 1, 2005 Share Posted June 1, 2005 can anyone tell me how easy it is to take the rear wing off , and how do to it? Very easy, you need to remove the plastic trim on the boot, this is clipped in place and can be removed by pulling on the trim. Once this is removed you will find 4 bolts, 2 on each side, unscrew these and the wing will lift off. It's a 5-10 minute job. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted June 1, 2005 Share Posted June 1, 2005 Thanks for the info Nic, I'll also need to remove the wing soon Quote Link to comment Share on other sites More sharing options...
Chipmunk Posted June 1, 2005 Share Posted June 1, 2005 Very easy, you need to remove the plastic trim on the boot, this is clipped in place and can be removed by pulling on the trim. Once this is removed you will find 4 bolts, 2 on each side, unscrew these and the wing will lift off. It's a 5-10 minute job. Be careful when removing the plastic trim on the boot though, as it cracks quite easily.Make sure you pull the panel at the points where they're clipped in. The rest after that is straightforward as detailed by Nic. Quote Link to comment Share on other sites More sharing options...
djg99 Posted June 1, 2005 Author Share Posted June 1, 2005 Cheers for that, took me ten minutes altho i cracked the plastic trim , next question, i've just brought a veilside spoiler but the holes dont line up, and i no it fits the supe as i got it from a member on the site, one side is ok but the other is out buy 3-4 mm, any ideas???????????????????? Quote Link to comment Share on other sites More sharing options...
Nic Posted June 1, 2005 Share Posted June 1, 2005 Also becareful when you put the plastic trim back on, to make sure the clips are lined up with the holes otherwise you will bend/break them. Can you not persuade the wing to flex 3-4mm to get the bolts in? Quote Link to comment Share on other sites More sharing options...
djg99 Posted June 1, 2005 Author Share Posted June 1, 2005 me and a mate tryed, but with no luck , mite have some shreaded wheat and try again!!!! Quote Link to comment Share on other sites More sharing options...
