Pudsey Posted June 11, 2010 Share Posted June 11, 2010 Hi everyone, Just wondered if anyone knows how to wire in a AEM Wide Band Gauge. All I need to know is where does each of the wires go. Have looked online, but with no joy so far. Then just thought I bet loads of people have fitted them before, so see if anyone here has a copy perhaps. Thanks for any help you can give in advance. Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted June 11, 2010 Share Posted June 11, 2010 Red - Ignition Black - Ground the other two are just analog and digital signal as far as i remember. Quote Link to comment Share on other sites More sharing options...
Pudsey Posted June 11, 2010 Author Share Posted June 11, 2010 Red - Ignition Black - Ground the other two are just analog and digital signal as far as i remember. Ah thanks very much for that. Does that mean the other two wires actually need to be attached all. Quote Link to comment Share on other sites More sharing options...
Rob W Posted June 12, 2010 Share Posted June 12, 2010 Ah thanks very much for that. Does that mean the other two wires actually need to be attached all. The other two are for datalogging and ECU connection bud Quote Link to comment Share on other sites More sharing options...
Lee P Posted June 12, 2010 Share Posted June 12, 2010 White wire goes to the ecu If your running aftermarket like solaris or AEM, if your on stock ecu don't worry. Quote Link to comment Share on other sites More sharing options...
G-NEMIE Posted June 12, 2010 Share Posted June 12, 2010 if you wanted you can connect blue / white wires to a serial (female) connector (pins 2 and 5) and connect to a laptop etc for data logging with hyperterminal (or AEM logger) for testing purposes.. regards jamie Quote Link to comment Share on other sites More sharing options...
Pudsey Posted June 12, 2010 Author Share Posted June 12, 2010 The other two are for datalogging and ECU connection bud White wire goes to the ecu If your running aftermarket like solaris or AEM, if your on stock ecu don't worry. if you wanted you can connect blue / white wires to a serial (female) connector (pins 2 and 5) and connect to a laptop etc for data logging with hyperterminal (or AEM logger) for testing purposes.. regards jamie Thanks very much gents!! Thats great help and really appreciated. Quote Link to comment Share on other sites More sharing options...
Pete Posted June 12, 2010 Share Posted June 12, 2010 This of help? http://www.mkivsupra.net/vbb/showthread.php?p=2787448#post2787448 Quote Link to comment Share on other sites More sharing options...
Pudsey Posted June 12, 2010 Author Share Posted June 12, 2010 This of help? http://www.mkivsupra.net/vbb/showthread.php?p=2787448#post2787448 Brilliant help Pete. I have wired the sensor in, but no joy for some reason. I will double check everything as soon as I can using the diagram. Brilliant stuff indeed. Quote Link to comment Share on other sites More sharing options...
Rob W Posted June 12, 2010 Share Posted June 12, 2010 Brilliant help Pete. I have wired the sensor in, but no joy for some reason. I will double check everything as soon as I can using the diagram. Brilliant stuff indeed. If you wire it up to the cigarette lighter it should be no prob. On the cigarette lighter is a ignition live and an earth, only two wires you need bud, red and black Quote Link to comment Share on other sites More sharing options...
