1 bar restricor ring did nothing, what can i do?
Lude
car is boosting like its going out of fasion.
the prev owner said it had a 1.2 or a 1.0 bar restricor ring on it.
boosted 1.4 even 1.5bar
ive put my new 1 bar ring on, its exactly the same size, :rolleyes:
is there a pipe i can put a welding tip in or something? on the wastegate? (thats what do on a 300zx to up the boost)
or other than restricter ring, how can i keep the boost down??
not sure without measuring, but i ordered it from whifbitz as a 1 bar ring
rarther than buying new ring with a tiny hole, and keep machining it out, refitting, testing,
theres gota be an easier way? fit UK wastegates so doesnt overboost?
My 1 bar rr was 42mm & was only boosting at .8 bar. I cut the hole to 60mm - 62mm & get 1 bar. Tbh they are a pain to cut (i did mine with an angle grinder) but unless you put back in cats its all you can do i think.
I don't think you can change the wastegate on the stock turbos unfortunately.
hmm ok.
i guess il order a ring with a considerably smaller hole in it than the usual 1 bar rings.
then hopefully thatl bring it down a bit. if too small il ave to guess a size to increase it to then.
is a real pain in the arse way of doing things isnt it?
Yes it is. I was lucky with mine as i tried it first with no rr but was hitting boost cut. So then took the angle grinder out & started cutting. Lucky enough i didn't go to big but made it about 60 - 62mm the first time i cut it.
It really would be a nuisance taking it in & out more than once.
There is no such thing as a 1bar restrictor ring, the size of hole required to limit it to 1bar will vary from car to car.
If the hole is exactly the same size as your other one then it'll boost exactly the same. You need to get one with a smaller hole and then widen the hole until it is boosting to the required pressure.
The stock turbos have an internal wastegate ie. it is part of the turbo housing and cannot be changed. Fitting a restrictor ring may be crude, but it is the simplest and cheapest way to limit the boost.
Just to support what Nic has said about RR's, I had one that held my car to slightly under 1.2 bar in the summer When I gave it to someone else their car over boost to just under 1.4bar. It is not rocket science, just get one with a smaller hole, use a vice and a file and keep trying it until you get the boost you want.
Looks like your wastegate doesn't open full,
maybe a vacuum hose on the actuator?
I had a 1,2 bar R-Ring (51mm//2inch) wich worked very nice,
best with boostcontroller...
boost controller cannot lower/limit the boost.. only increase.
but thanks for the suggestions on vacuum leak on the actuator
