oil temp/oil pressure
supra mkiv
hallo guys
I would like to hear if there are some who have some experience with such an adapter for oil pressure / temp. it must sit on a 2jzgte engine. will provide lubrication problems for engine or
when I have doubts whether it can be the cause of defective Rod Bearings and uined crank. then it must be the lubrication problem
hallo guys
what cars do you drive. na supra or tt supra.
I've had for a lubrication problem in my engine, so I try to find out what is causing the lubrication problem.
run for the single turbo and it has destroyed two crankshafts. so i suspect my oil pump for the problem
