Supra losing pressure?
Guest Nickwan
Guest Nickwan
Hi guys im new here and allredy have a questionm that i relly hope that you can help me with :)
i have a supra 3.0 twin turbo from 1993
Here is my spec list
APEXI AIR FILTER
RSR FULL THROUGH RACING EXHAUST-
DECAT 3"
IRRIDIUM SPARK PLUGS
UPRATED FUEL PUMP
550CC INJECTORS
TEIN COILOVERS
RPS DOUBLE PLATE CLUTCH WITH LIGHTWIEGHT CYN R G FLYWHEEL
BLITZ BOOST CUT DEFENDER
well my problem is when i hammer down the gass then its like when it has to go from turbo 1 to turbo 2 its losing bressure, i had a cat on (to get it through registration) but i have replaced that with a 3" pipe.
here is a Measurement that i have got while the cat was on.
http://www.bilgalleri.dk/uploads_xl_wm/1935530.jpg?07-06-2010 10:44:39
hope you understand my poor english im from denmark:)
and i relly hope that you guys can help cuz its relly bothering me:/
thx from Nicklas Jensen :)
Guest Nickwan
relly does it? i diden thought that it should loose pressure?
btw when i tryed to make a burn out with the cat on i did "jump" after i replaced the cat i dont "jump" that much anymore.. :)
and try to see the HP "only" 354 shoulden i have colse to 400 or is it only when you take it to 1.2 bar? cuz one told me that my car with that spec list shopuld have close to 400?
Guest Nickwan
hehe no problem im just waiting :)
->! and thx for all the help guys :) relly glad that i joined this site, so many nice and helpful people:) !
Guest Nickwan
hi Ian C
i took a look at the link you linked, and the only problem i can see is my turbo #2 maby starts a little bil late? or what?
cuz i have no problem passing 0.8 bar im driving with 1.0 bar.
Guest Nickwan
well maby im just wrong but i thought that the NM curve should go up all the time and not dive? that guy that did the dyno test on my car said it looked wired that the NM curve dived between the 2 turbos?
and the second problem is.. i took the car to a dyno test and i only got 356HP (i hat a cat on at that time, i have replaced the cat now with 3" pipe) and as far as i know my car have the BPU so shoulden i get close to 400 HP ? and can the cat be the reason why i only got 356 HP ? :)
