miko_supra Posted June 9, 2010 Share Posted June 9, 2010 I'm going to be wrapping my tubular manifold this weekend and could do with some pics so I can basically copy what others have successfully done! Mike Link to comment Share on other sites More sharing options...
jackso11 Posted June 9, 2010 Share Posted June 9, 2010 http://www.heavenlyheatpads.com/index.php?p=2_2 Link to comment Share on other sites More sharing options...
sdistc Posted June 9, 2010 Share Posted June 9, 2010 (edited) A little writeup from my efforts http://www.supraforums.com.au/forum/showpost.php?p=836719&postcount=337 I've been meaning to do this for some time now - I thought the benefits of insulating as many exhaust parts as possible was an excellent idea for a couple of reasons: 1) massive reductions in underbonnet temperatures (which without a vented bonnet have already resulted in some plastic parts melting!) 2) some increase in turbine spool speed. There has been a lot of conjecture and anecdotal suggestion that heat-wrapping leads to manifold cracking and/or faster deterioration of exhaust components. However, I have dealt with this possibility by initially purchasing a high quality thick stainless steel HKS manifold, then high-temperature ceramic coating it, then wrapping with 1" fibreglass-based heat-wrap, and finally sealing the cured wrap with high- temperature engine enamel. Tools required Heat wrap - prior to soaking in water BEFORE: Stainless steel HKS manifold AFTER HEAT-COATING: Fully wrapped and cured manifold Sealed & wrapped manifold Edited June 9, 2010 by sdistc (see edit history) Link to comment Share on other sites More sharing options...
miko_supra Posted June 9, 2010 Author Share Posted June 9, 2010 (edited) A little writeup from my efforts http://www.supraforums.com.au/forum/showpost.php?p=836719&postcount=337 I've been meaning to do this for some time now - I thought the benefits of insulating as many exhaust parts as possible was an excellent idea for a couple of reasons: 1) massive reductions in underbonnet temperatures (which without a vented bonnet have already resulted in some plastic parts melting!) 2) some increase in turbine spool speed. There has been a lot of conjecture and anecdotal suggestion that heat-wrapping leads to manifold cracking and/or faster deterioration of exhaust components. However, I have dealt with this possibility by initially purchasing a high quality thick stainless steel HKS manifold, then high-temperature ceramic coating it, then wrapping with 1" fibreglass-based heat-wrap, and finally sealing the cured wrap with high- temperature engine enamel. Tools required http://i38.tinypic.com/29bikv7.jpg Heat wrap - prior to soaking in water http://i33.tinypic.com/155i653.jpg BEFORE: Stainless steel HKS manifold http://i38.tinypic.com/2la304p.jpg AFTER HEAT-COATING: http://i34.tinypic.com/17p9a8.jpg Fully wrapped and cured manifold http://i34.tinypic.com/4lokdi.jpg http://i34.tinypic.com/30biwlt.jpg Sealed & wrapped manifold http://i37.tinypic.com/2jd118i.jpg http://i38.tinypic.com/1zz1cw8.jpg Very nice, thanks! Did you coat it yourself? If so what did you use? Edited June 9, 2010 by miko_supra (see edit history) Link to comment Share on other sites More sharing options...
jevansio Posted June 9, 2010 Share Posted June 9, 2010 Couple of pics I took, I used both 1" & 2" thick wrap (just as I already had it), but in hindsight would use 1" all over as the manifold is quite a complicated shape Link to comment Share on other sites More sharing options...
michel lane Posted June 9, 2010 Share Posted June 9, 2010 here is mine ... wife didnt feel very well after:d Link to comment Share on other sites More sharing options...
miko_supra Posted June 9, 2010 Author Share Posted June 9, 2010 Couple of pics I took, I used both 1" & 2" thick wrap (just as I already had it), but in hindsight would use 1" all over as the manifold is quite a complicated shape http://www.mkivsupra.net/vbb/attachment.php?attachmentid=95189&stc=1&d=1246476359 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=95190&stc=1&d=1246476359 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=95191&stc=1&d=1246476359 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=95192&stc=1&d=1246476359 Thanks Jay. Did you wet yours when wrapping it? I've bought a load of 1" stuff to do it with. Link to comment Share on other sites More sharing options...
sdistc Posted June 9, 2010 Share Posted June 9, 2010 Very nice, thanks! Did you coat it yourself? If so what did you use? Nope, I got the tuning shop to get it done. Can't recall what it is, but probably some generic high-temp coating. Link to comment Share on other sites More sharing options...
sdistc Posted June 9, 2010 Share Posted June 9, 2010 Thanks Jay. Did you wet yours when wrapping it? I've bought a load of 1" stuff to do it with. You need to wet it to activate the fibreglass resin. Just don't rub your eyes. Link to comment Share on other sites More sharing options...
jevansio Posted June 9, 2010 Share Posted June 9, 2010 I didn't wet it no bud Link to comment Share on other sites More sharing options...
TLicense Posted June 9, 2010 Share Posted June 9, 2010 You need to wet it to activate the fibreglass resin. Just don't rub your eyes. Hmmm, I'm pretty sure it doesn't have any resin in it. Certainly not the stuff I've been using anyway. Link to comment Share on other sites More sharing options...
sdistc Posted June 9, 2010 Share Posted June 9, 2010 Hmmm, I'm pretty sure it doesn't have any resin in it. Certainly not the stuff I've been using anyway. haha yeah I had a quick check online and I now think I was totally talking out of my arse. Thanks for correcting my faulty understanding - wetting the wrap and stretching it while applying it simply means that it tightens when it dries. Link to comment Share on other sites More sharing options...
EdMorris Posted June 9, 2010 Share Posted June 9, 2010 Whatever you do, wear some gloves and a mask. This stuff is nasty and the fibres get everywhere. Link to comment Share on other sites More sharing options...
Dave Posted June 9, 2010 Share Posted June 9, 2010 would this be of any advantage to my n/a----------- [waits to get flamed] Link to comment Share on other sites More sharing options...
miko_supra Posted June 11, 2010 Author Share Posted June 11, 2010 Started a bit tonight. Obviously the loose bits and plastic cable ties will be getting sorted! Link to comment Share on other sites More sharing options...
Ricky49 Posted June 11, 2010 Share Posted June 11, 2010 would this be of any advantage to my n/a----------- [waits to get flamed] Yes it will give you a extra 748hp. Link to comment Share on other sites More sharing options...
