Air Con
cainhead
Just reading a few threads on air con as mine seems to have stopped working. The light still comes on but no cold air. Other than re-gassing is there anything I should look for that could tell me otherwise. Only asking before I go and spend money on a re-gas.
Cheers for any help in advance.
If you have no gas. you have a leak. Get a small amount of gas/dye/oil put in run it with the air con on and look for leaks. If you can't see any yourself, take it to the garage that regassed it and they will use ultraviolet light to pinpoint the leak. I'd say condensor but but get it all checked out first.
