Knocking
Guest craggle
Guest craggle
I have a knocking comming from under the car. I have had it up on a ramp and had a pull and push but cant see anything loose.
It happens when changing gear or comming off the throttle, you can feel a knock both through the gear leaver and the clutch. There is also an audio knock.
Any ideas or common issues??
TT/ NA a clue would be nice!!!:eyebrows:
Gearbox mounts, subframe mounts, flywheel, gearbox loose,propshaft all could be the knock dude.
Guest craggle
Sorry. Its a 93 NA with a 6 speed. Had the car on a 4 post as the kit on the car means a 2 post wont get under the skirts. Had a good old pull and push under but couldn't feel anything.
Thinking I might bite the bullet and pop into a local garage to get them to have a look see. Just wondering if there was any common issues around this area.
Thanks for helping though. :)
Front subframe bolts is a favorite they need to be KIN tight.
