ray007 Posted June 6, 2010 Share Posted June 6, 2010 Hi all im thinking of getting 720cc or 800cc injectors for my T61 coversion to allow for future plans. Just wondering if you can get these like the 550 or 650 drop in injectors? or would i need an uprated fuel rail? any advice would be much appreciated thanks guys Quote Link to comment Share on other sites More sharing options...
Homer Posted June 6, 2010 Share Posted June 6, 2010 720 and 800 are available as drops in's for the TT. They've been used by many people here without issue. PE and Sard both supply these, though there are many more, depending on budget. My last supra has been using 800cc PE drop in's for the last 3 years or so. Quote Link to comment Share on other sites More sharing options...
Geo Posted June 6, 2010 Share Posted June 6, 2010 What Homer said, ^^^^^^^ iv got PE 800cc Quote Link to comment Share on other sites More sharing options...
Jamesy Posted June 6, 2010 Share Posted June 6, 2010 yep - i got some 800cc SARD drop in's mate think they came from Paul W Quote Link to comment Share on other sites More sharing options...
ray007 Posted June 6, 2010 Author Share Posted June 6, 2010 thanks guys, im on a budget so which ones are the cheapest? any links Quote Link to comment Share on other sites More sharing options...
ray007 Posted June 6, 2010 Author Share Posted June 6, 2010 720 and 800 are available as drops in's for the TT. They've been used by many people here without issue. PE and Sard both supply these, though there are many more, depending on budget. My last supra has been using 800cc PE drop in's for the last 3 years or so. thanks darryl, ive just seen your garage, with the t67 and all the mods your cars only pushing 460 at the wheels? is that right? i thought you could do atleat 600-650 with them mods? Quote Link to comment Share on other sites More sharing options...
Jamesy Posted June 6, 2010 Share Posted June 6, 2010 none are really cheap mate - you'll spend £600+ for a decent set of drop ins Quote Link to comment Share on other sites More sharing options...
Homer Posted June 6, 2010 Share Posted June 6, 2010 thanks darryl, ive just seen your garage, with the t67 and all the mods your cars only pushing 460 at the wheels? is that right? i thought you could do atleat 600-650 with them mods? It was running 1.4 bar, safe mapping and stock cams so the BHP is bang on for that It's was within 1 bhp of the bhp JamieP had with the same turbo, engine spec and boost on his current car, so is a good benchmark. Things have moved on since then, especially as to what boost it's considered safe to run with an unopened engine These days I'd be likely trying for 1.7bar on the same setup. I'd not expect more than 600bhp (flywheel) without making a lot more changes, regardless of boost. The XS manifold would also likely have become a big issue at those levels. none are really cheap mate - you'll spend £600+ for a decent set of drop ins Sards are about £450-500 delivered, PE's about £600-650 as you say, high end ones are best not to ask about Quote Link to comment Share on other sites More sharing options...
Ricky49 Posted June 6, 2010 Share Posted June 6, 2010 I got some sard 800cc from Whifbitz paid less than £600 for them. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 6, 2010 Share Posted June 6, 2010 These will fit the stock rail. SH800A Power Enterprise Injectors 800cc Quote Link to comment Share on other sites More sharing options...
jayssupra Posted June 9, 2010 Share Posted June 9, 2010 It was running 1.4 bar, safe mapping and stock cams so the BHP is bang on for that It's was within 1 bhp of the bhp JamieP had with the same turbo, engine spec and boost on his current car, so is a good benchmark. Things have moved on since then, especially as to what boost it's considered safe to run with an unopened engine These days I'd be likely trying for 1.7bar on the same setup. I'd not expect more than 600bhp (flywheel) without making a lot more changes, regardless of boost. The XS manifold would also likely have become a big issue at those levels. Sards are about £450-500 delivered, PE's about £600-650 as you say, high end ones are best not to ask about Sards are about £450-500 delivered. From were i can't find any 800cc injectors for less than £650 Quote Link to comment Share on other sites More sharing options...
Scott Posted June 9, 2010 Share Posted June 9, 2010 http://www.flat4online.co.uk/catalog/product_info.php?pName=800cc-sard-injectors-for-mk4-9398-toyota-supra&cName=supra-jza80-fuel-system Under £380 from there? Am I just a googling machine? I seem to find things with ease, usually by clicking the first link in google after a search, most people seem to struggle. Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 9, 2010 Share Posted June 9, 2010 Does the NA fuel rail fit the Turbo head in terms of port spacing and mounting points? Quote Link to comment Share on other sites More sharing options...
jayssupra Posted June 9, 2010 Share Posted June 9, 2010 http://www.flat4online.co.uk/catalog/product_info.php?pName=800cc-sard-injectors-for-mk4-9398-toyota-supra&cName=supra-jza80-fuel-system Under £380 from there? Am I just a googling machine? I seem to find things with ease, usually by clicking the first link in google after a search, most people seem to struggle. Already tryed there mate, if you read it properly it says £380 for 4x800cc injectors not 6. Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 9, 2010 Share Posted June 9, 2010 (edited) Does the NA fuel rail fit the Turbo head in terms of port spacing and mounting points? I only ask as it could be a cheap top feed conversion and top feed injectors are nice and cheap from FiveO Motorsport in the US (come checked and in balanced sets too). Having seen the results from brand new out of the box Sard and Blitz side feed injector flow tests on a mates ANSU I wouldn't fit them in a lawn mower. Edited June 9, 2010 by Nodalmighty (see edit history) Quote Link to comment Share on other sites More sharing options...
