Sports Cat and Blitz Midpipe?
RedT18
Hey guys,
I have to get german MOT and therefore I need to install some cat. Current exhaust:
Decat Downpipe mild steel, Blitz Frontpipe and a Nur Spec R at the end. I wanted to install the cat somewhere in Blitz frontpipe but after having a look under the car, i recognized that will get some issues with fitting/package.
Actually, I have 3 options for the Cat:
1. 100 mm dia
2. 120 mm dia
3. 130 mm dia
Keep in mind that the bigger the cat is, the less backpressure it will make. On JDM BPU it makes no difference due to the RR but I am planning to go for Single thi winter and I dont want to change the whole exhaust system again.
Did anyone of you ever try to install a sports cat in the frontpipe? Pics? Comments? Hints?
I will attache some pics of the current setup...
http://img189.imageshack.us/img189/8682/img0872e.jpghttp://img44.imageshack.us/img44/2183/img0859w.jpghttp://img715.imageshack.us/img715/8961/img0856ro.jpghttp://img715.imageshack.us/img715/7919/img0855p.jpg
With an E Number, Sports Cat should be no Problem for the TÜV ;)
I would take the 130 cat if you are going Single because else it will be the bottle neck.
Also take one with 100cells. I'm also thinking of going with one. TÜV is sometimes a real pain in the a.. ^^
Where did you TÜV your Nur Spec R? I'm currently in a search for someone who will.
