Need4Speed Posted June 6, 2010 Share Posted June 6, 2010 Is there an alternative spec fluid to the Toyota official stuff? It seems to be unavailable. (I have used the search!) Quote Link to comment Share on other sites More sharing options...
garethr Posted June 7, 2010 Share Posted June 7, 2010 Have you tried Lexus? Quote Link to comment Share on other sites More sharing options...
Terminator Posted June 7, 2010 Share Posted June 7, 2010 Been loads of threads on this, Type VI fluid. Quote Link to comment Share on other sites More sharing options...
Miguel Posted June 7, 2010 Share Posted June 7, 2010 http://www.mkivsupra.net/vbb/showpost.php?p=2492468&postcount=2 Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted June 7, 2010 Author Share Posted June 7, 2010 (edited) Been loads of threads on this, Type VI fluid.I even had a couple of litres left over when I sold my previous Supra - couldn't give it away... so I chucked it 2 years ago! Problem is that I'm not in Britain and here in France I've never found a Toyota dealer whose even seen a mkiv TT never mind supplied transmission oil. The other issue is that all French Supras were manual! So the question still stands... is there an alternative that's up to spec? Edited June 7, 2010 by Need4Speed added a bit more (see edit history) Quote Link to comment Share on other sites More sharing options...
garethr Posted June 7, 2010 Share Posted June 7, 2010 I even had a couple of litres left over when I sold my previous Supra - couldn't give it away... so I chucked it 2 years ago! Problem is that I'm not in Britain and here in France I've never found a Toyota dealer whose even seen a mkiv TT never mind supplied transmission oil. The other issue is that all French Supras were manual! So the question still stands... is there an alternative that's up to spec?I repeat.... have you tried Lexus France The same fluid (Toyota Type IV) is used in "Lexus" autoboxes. Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted June 7, 2010 Author Share Posted June 7, 2010 I repeat.... have you tried Lexus France The same fluid (Toyota Type IV) is used in "Lexus" autoboxes.There's no Lexus dealer within a hundred miles of here. Andorra's the nearest! Quote Link to comment Share on other sites More sharing options...
Terminator Posted June 7, 2010 Share Posted June 7, 2010 Try Oilman, member here, he may be able to help you. Quote Link to comment Share on other sites More sharing options...
tDR Posted June 7, 2010 Share Posted June 7, 2010 Try Oilman, member here, he may be able to help you. He can supply Amsoil 'fully synth' ATF for Toyotas - used it successfully in my BL auto to help keep trans temps down and the fluid good with drag abuse. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted June 7, 2010 Share Posted June 7, 2010 Here is the part number mate 005F02 Power stg flu T08886-82025 Quote Link to comment Share on other sites More sharing options...
Miguel Posted June 7, 2010 Share Posted June 7, 2010 Any Toyota main dealer should be able to get it whether they are in France, Poland, Ukraine, wherever. If it is on Toyotas EPC system then they can supply it. If they say they can't then find a dealer that knows what he is talking about and complain to Toyota France. If you can't be bothered with all that then contact Steve Manley at Inchape and see if he will deliver some to you. Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted June 7, 2010 Author Share Posted June 7, 2010 Cheers Miguel et al. What I was hoping to hear was that there's an alternative that isn't at the extortionate price Toyota command. Engine oil here is almost half the UK price and I had hoped to find a TX oil at the same rate. Quote Link to comment Share on other sites More sharing options...
