Miguel Posted June 6, 2010 Share Posted June 6, 2010 Thicker HG to lower compression work, but they royally screw up the squish area. Not the best way of lowering the CR IMO, but it's cheap. You pays your money and makes your choice. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 6, 2010 Author Share Posted June 6, 2010 i think im going to go with the boost logic kit with the hg and bolts included then decide what to do when the engine is out as taking the head off aint a major job. Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 6, 2010 Share Posted June 6, 2010 Thicker HG to lower compression work, but they royally screw up the squish area. Not the best way of lowering the CR IMO, but it's cheap. You pays your money and makes your choice. Right on the money there. Although the TT and NA share the same squish area they achieve this by two different ways so whilst adding a thicker HG seems a quick way to gain some headroom for boost you could also introduce engine killing det not to mention the engine probly wont peform as well as its should. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 6, 2010 Author Share Posted June 6, 2010 Right on the money there. Although the TT and NA share the same squish area they achieve this by two different ways so whilst adding a thicker HG seems a quick way to gain some headroom for boost you could also introduce engine killing det not to mention the engine probly wont peform as well as its should. so would you recommend tt pistons too then mate? i cant see what the problem is with just using the hg and uprated bolts as im not aiming for bhp over 400. Quote Link to comment Share on other sites More sharing options...
RobD Posted June 6, 2010 Share Posted June 6, 2010 Are the TT pistons just a drop in or does the block need to be bored out to accomadate? Quote Link to comment Share on other sites More sharing options...
Miguel Posted June 6, 2010 Share Posted June 6, 2010 Unmolested they are the same size bores, but you should always check the clearances on building and adjust as necessary. Quote Link to comment Share on other sites More sharing options...
RobD Posted June 6, 2010 Share Posted June 6, 2010 Nice one! Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 6, 2010 Share Posted June 6, 2010 so would you recommend tt pistons too then mate? i cant see what the problem is with just using the hg and uprated bolts as im not aiming for bhp over 400. As i said in this thread http://www.mkivsupra.net/vbb/showthread.php?t=209281 Its a dodgy bodge but i suppose with your power goals you will get away with it. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 6, 2010 Share Posted June 6, 2010 when you say uprated h/g , do you mean same thickness but stronger because that will be fine . you wont need tt pistons with stock injectors but if you ever want to go for higher numbers they will be needed Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 7, 2010 Author Share Posted June 7, 2010 when you say uprated h/g , do you mean same thickness but stronger because that will be fine . you wont need tt pistons with stock injectors but if you ever want to go for higher numbers they will be needed hi craig im going with stock injectors for the time being, sent boost logic a email today about the stage 1 kit just waiting a reply to see what they can do it for. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 7, 2010 Author Share Posted June 7, 2010 emailed a few companys today about the boost logic kit but no replys yet, also enquired about the turbonetics kit at http://www.titanmotorsports.com/tunakit93su.html not sure if its better than the boost logic but ill wait to hear from them. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 7, 2010 Author Share Posted June 7, 2010 the aim lol- Quote Link to comment Share on other sites More sharing options...
