Wastegate VSV
SupraShaun
hi what happens when this is u/s ???
It depends on the failure mode. If it's jammed closed, the turbos won't spool up to full boost as quickly. However it probably won't change the spool time too much. Less than a second difference I would say at a guess.
If it's jammed open, the boost will be uncontrollable and will go well above stock boost levels.
  • 3 weeks later...
  • 2 weeks later...
  • 3 weeks later...
