add heywood Posted June 4, 2010 Share Posted June 4, 2010 Will an oem headgasket be the best to replaced mine with, or should I go for a HKS or similar? Also what head bolts are recommended to use? Link to comment Share on other sites More sharing options...
TLicense Posted June 4, 2010 Share Posted June 4, 2010 I would go with a stock Toyota head gasket. They're good quality and steel laminate (the same as a HKS one). The only reason I would go for an alternative would be if I wanted to change the compression ratio for some reason. As far as headbolts, personally I would go for ARP head studs, but to be honest I've not heard of anyone having had a problem with the stock bolts clamping force. Link to comment Share on other sites More sharing options...
dude Posted June 4, 2010 Share Posted June 4, 2010 As above, if you feel flush go for the exotic ARP studs. Link to comment Share on other sites More sharing options...
Kirk Posted June 4, 2010 Share Posted June 4, 2010 Or you could get the normal ARP studs There more servicable than stock bolts hence why people switch. To me it makes total sence to make the change Link to comment Share on other sites More sharing options...
Swampy442 Posted June 4, 2010 Share Posted June 4, 2010 Yup, stock Toyota gasket Link to comment Share on other sites More sharing options...
Lee P Posted June 4, 2010 Share Posted June 4, 2010 Stock gasket, standard ARP head stud kit. Link to comment Share on other sites More sharing options...
