What headgasket to use for big single?
add heywood
I would go with a stock Toyota head gasket. They're good quality and steel laminate (the same as a HKS one).
The only reason I would go for an alternative would be if I wanted to change the compression ratio for some reason.
As far as headbolts, personally I would go for ARP head studs, but to be honest I've not heard of anyone having had a problem with the stock bolts clamping force.
