stevie_b Posted June 4, 2010 Share Posted June 4, 2010 I'm getting the cambelt (+ tensioner), aux belt and crank pulley replaced on my NA supra soon. Are there any other items that I should consider replacing as a matter of course whilst that work's being done? I was thinking about the front main oil seal: is that worth replacing? Other suggestions also welcome. Quote Link to comment Share on other sites More sharing options...
Jimmer Posted June 4, 2010 Share Posted June 4, 2010 I would deffo replace the front main as its cheap and easy to do and will probably be leaking! Whilst its stripped you can check water pump/alternator/PAS bearings etc Quote Link to comment Share on other sites More sharing options...
RobD Posted June 4, 2010 Share Posted June 4, 2010 I'd do the water pump whilst your there! For what it costs it's worth it, sod's law is that it will go after you've had the belt changed and will need it all doing again! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 4, 2010 Share Posted June 4, 2010 yeah agree with the water pump mate. i recently did the oposite, my water pump failed so i replaced the belt and tensioner at the same time. Quote Link to comment Share on other sites More sharing options...
