uk callipers respray?
justice
iv got my UK spec callipers here in front of me and was just wondering if I get them powder coated tomorrow will it ruin any of the seals, or will the front 2 callipers need stripping right down?
I've stripped most of them down but not sure how far I'll have to go?!
The powder coating process we do in work, means they would have to go into a 270 degree oven for the powder paint to cure.So any rubber seals would have to be removed or they would simply melt.
Not sure if there are any other methods of powder coating though?
Surely spirited driving generates more heat than that?
You would think so mate yes, but how much heat actually reaches the seals on a working caliper?
In our oven, the seals would be subject to the full 270 deg
If i remember correctly there are 2 rubber ring seals in each caliper.
I also don't think it's recommended to split the calipers, as they can leak afterwards, unless you fit new seals ov course.It may be worth checking to see if the seals are available to buy seperately before hand?
Chris Wilson stocks them, you cannot get them from Toyota. :)
is this what i need incase it all goes wrong?
http://www.biggred.co.uk/toyotashop.html
That's the kit for the piston seals which you should replace if you're stripping the caliper down.
I don't know if it includes the 0 ring seals that you need to replace if you split the caliper, you'll have to ask them.
Like I said before, Chris Wilson sells these 0 ring seals
I painted my UK's with spray can's as Steve stated above.I used heatproof primer, 3L2 colour matched spray paint from Sparesworld and heatproof laquer.The end result was cracking.
They've been on the car for over 6 months now and they still look mint :)
They took a while to do mate, but the end result was good.I used:
http://cgi.ebay.co.uk/HYCOTE-RED-VHT-SPRAY-PAINT-400ml-BRAKE-CALIPERS-ETC-/130392808688?cmd=ViewItem&pt=UK_Body_Shop_Supplies_Paint&hash=item1e5c045cf0
http://cgi.ebay.co.uk/HYCOTE-CLEAR-VHT-SPRAY-PAINT-400ml-BRAKE-CALIPERS-/130392244435?cmd=ViewItem&pt=UK_Body_Shop_Supplies_Paint&hash=item1e5bfbc0d3
The first link is the red paint i used, but to be honest the finish was a pinky/orange colour and it was very matt like primer.So i used it has it as primer.I then sprayed the normal red (Sparesworld) spray paint on top of that.And then i used 2 cans of the clear VHT paint to finish (Second link)
Hope this helps :thumbs:
It may be better mate.Powder paint dries like concrete, so if the ring seals did become damaged by heat, you would probably have some trouble splitting them once the paint is cured.
Ive just stripped a pair of uk spec front calipers that were powder coated and they came apart very easily.
The internal seals that seal the 2 halves were fine and hadnt melted in the oven. The oven temp used on these was 200 degrees C, the outer dirt seals, pistons and piston seals were removed.
If you split the two halves you will need to replace the internal seals, done correctly they wont leak. Ofcourse you need to put bolts in the threads M10X1 for the fluid line and bleed nipple and M12X1.25 for the mounting thread, you'll also need to mask off the piston bores.
The seal kit you get off Toyota doesnt include the internal seals and isnt available from Toyota, i got mine from Chris Wilson
what about ur decals, how and at what point in the process did u put them on?
I simply stuck the decals on top of laquer coat.I suppose you could stick them to the colour coat, and then laquer over them for peace of mind, but mine are fine after many months :)
I would suggest getting the decals from below.These are good quality and are proper high temp ones.
http://cgi.ebay.co.uk/TOYOTA-Supra-Brake-Caliper-Calliper-Decals-Stickers-/380238835484?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5888002f1c
Thanks for all the help people.
I have callipers stripped down (in half) but Iv'e left the pistons in as I would of thought they could stand the temperature of being powder coated.
If I'm wrong?? I might need to hurry back down to the spray bay, oh please someone get back to me...
