Desperate for a turbo charger
Guest xxmussyxx
Guest xxmussyxx
Hi peeps im new on here i desperatly need a turbocharger for supra on a n reg twin turbo auto, the small turbo is fine the big one is dead real desperate contact 07860554432 many thanks
Guest xxmussyxx
hi , well basically 1st turbo kicks in as u floor it it just dies no power boost at all but if you keep your foot half way it allows 1st turbo to still run and its fine, buit 2nd turbo will not engage at all thanks ive had this problem for a few months now really wana get it sorted
before you dive in changing turbos, you need to take a look at the VSV/actuators which control the pre-spool for the second turbo. A quick test is to bypass the seqential system and put it in to True Twin Conversion - this allows both turbos to come on at the sametime and will tell you if No2 is fubard.
