NOS Posted June 2, 2010 Share Posted June 2, 2010 What's causing this?! Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted June 2, 2010 Share Posted June 2, 2010 Condensation, one of the seals is broken, could be a bulb seal or the outer one, time for a new set of lights Quote Link to comment Share on other sites More sharing options...
NOS Posted June 2, 2010 Author Share Posted June 2, 2010 Thanks TooQuick - does this mean I should try justifying upgrading to a set of glass headlights () or is this problem easily rectified? Quote Link to comment Share on other sites More sharing options...
L18msy Posted June 2, 2010 Share Posted June 2, 2010 Headlamp has moisture in it.It is either got a leak with the seals at the back of the light, or the light aint breathing properly. I had this problem i drilled two small holes on the underside of the lamp to sort the problem out as my seals were spot on. Quote Link to comment Share on other sites More sharing options...
NOS Posted June 2, 2010 Author Share Posted June 2, 2010 Headlamp has moisture in it.It is either got a leak with the seals at the back of the light, or the light aint breathing properly. I had this problem i drilled two small holes on the underside of the lamp to sort the problem out as my seals were spot on. Cheers. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted June 2, 2010 Share Posted June 2, 2010 Thanks TooQuick - does this mean I should try justifying upgrading to a set of glass headlights () or is this problem easily rectified? You could go UK Glass or Facelift, your Jspec lights are a little dull as well as full of moisture A new set of lights transforms a Supra IMO Quote Link to comment Share on other sites More sharing options...
NOS Posted June 2, 2010 Author Share Posted June 2, 2010 UK Glass - don't the lights have to be J if it's a Jap import? Quote Link to comment Share on other sites More sharing options...
heckler Posted June 2, 2010 Share Posted June 2, 2010 UK Glass - don't the lights have to be J if it's a Jap import? nope. I have UK Glass lights with black reflector on my JSpec.. Quote Link to comment Share on other sites More sharing options...
NOS Posted June 2, 2010 Author Share Posted June 2, 2010 Ok cool. I didn't know that. Thanks - I'll start checking out eBay. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted June 2, 2010 Share Posted June 2, 2010 Ok cool. I didn't know that. Thanks - I'll start checking out eBay. Toyota would be a better option, they are around £300 a pair for UK's or they were when I brought them last Quote Link to comment Share on other sites More sharing options...
L18msy Posted June 2, 2010 Share Posted June 2, 2010 (edited) I have glass headlamps on my import Edit: a bit slow Edited June 2, 2010 by L18msy (see edit history) Quote Link to comment Share on other sites More sharing options...
NOS Posted June 2, 2010 Author Share Posted June 2, 2010 I have glass headlamps on my import Just checked out your Garage - they're nice. Do you have 10,000k HID's in them? Quote Link to comment Share on other sites More sharing options...
L18msy Posted June 2, 2010 Share Posted June 2, 2010 Just checked out your Garage - they're nice. Do you have 10,000k HID's in them? Just went for 8k hids to keep the plod away. Quote Link to comment Share on other sites More sharing options...
NOS Posted June 2, 2010 Author Share Posted June 2, 2010 Quote Link to comment Share on other sites More sharing options...
L18msy Posted June 2, 2010 Share Posted June 2, 2010 Quote Link to comment Share on other sites More sharing options...
marcAB10 Posted June 2, 2010 Share Posted June 2, 2010 i reckon it would be worth saving a bit more and getting a new set of facelift lights, especially on a white car, the darker inserts look a lot better imo. Quote Link to comment Share on other sites More sharing options...
jim Posted June 2, 2010 Share Posted June 2, 2010 (edited) They're facelifts you've got Nos, I'd be trying my best to clear them and give them a refurb before giving up on them bud. Passenger side one's the easy one to get out too (as the airbox isn't obstructing it). There's a bolt on the left which is obvious, and two nuts on the right in the wing, undo them being careful not to drop the nuts, disconnect the lamps (3 connectors, small screwdriver is handy for this too) and take it out. Get the hairdryer out and dry it out, replace the foam in the bungs at the back with new bits of sponge from the bathroom, then put it back on the car. Take care you make sure that the bulb holders are in the right way and seated properly as this could be where the condensation's coming from. Hopefully it won't come back. Btw, did you wash the car late in the evening recently? That can trigger the condensation build up inside. To refurb, use either Meguiar's plast-x or some metal polish (autosol, megs etc) and get buffing, or some wet and dry with plenty of water, then buff with an orbital buffer and some compound. They'll surprise you how well they'll come up. Edited June 3, 2010 by jim (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted June 3, 2010 Share Posted June 3, 2010 (edited) 1 of my lights had a little condensation in it & when parked in the sun on a hot day it went alot worse. I just put it in the garage with the lights on for an hour turned it of & left it for a couple of days. It cleared up & never came back. I blamed my power washer getting water passed the seal . I agree though the facelifts look alot better on a white car. Never mind Jim just pointed out you already have facelifts. Edited June 3, 2010 by Suprab1 (see edit history) Quote Link to comment Share on other sites More sharing options...
