By-passing the factory amp
supra steveo
Today i by-passed the stock factory amp so it could be removed from the car to give a little extra space under the passenger seat
what is needed
a pair of wire cutters
a crimping tool
1st picture is of the amp in its place
2nd picture of the amp removed
3rd picture of the 1st clip needed to do the by-pass
4th picture of the 2nd clip needed to do the by-pass
5th picture how it should look when done
on picture 3 you will need the sky blue wire and the purple wire
on picture 4 you will need the wire to the left of the thick brown wire and the wire in the bottom corner of the clip
these need to be conected by a clip or bullet conectors to make them loop and by-pass the amp so now there will be power to the after market stereo while the amp is removed
i cant remember which way the wire are connected but i think it is
purple wire --------- blue wire
sky blue wire -------grey wire
if this is wrong just change them around, when you are done wrap with electicians tape and stick it under the carpet, you will also need to run your speakers off the back of the after market headunit
Edited by supra steveo (see edit history)
I'm slightly baffled by this (nice post though :) ). Why would you need to go to the bother of altering the wiring - or have I missed the point altogether? If you're using the original (not hacked about) Toyota wiring and installing a new head unit, then there's no need to go to that much effort.
When I removed my stock Toyota system, I just used an Autoleads PC2-17-4 ISO cable to connect the new head unit to the existing Toyota wiring. It took a few seconds and I then just unplugged the amp under the seat and removed it as it was automatically by-passed by using the Autoleads PC2-17-4 cable.
I agree, but its nice to no an alternative way
Lol fair one but my version is cheap as chips
Yeah, fair point. I had to splash out £2.75 (inc P&P) for my ISO cable. Perhaps I shouldn't have been quite so hasty. :)
Full credit to you though for figuring out the wiring...
