ABS light cluster loose Connection
Jellybean
The Light Cluster for the ABS and Oil cluster has a loose connection, they work fine if I press the wire in but as soon as I drive they wont work again till I press on the loom again,
Whats the best way to fix this? And out of curiousty what is the DB level with just second CAT in on TT?
Hi mate, the same thing was happening to me & it turned out to be dry solder. Just remove the light cluster open it up & resolder the joints & it will be perfect again.
