How Much For A Service?
SupraD06
Hi Guys, just after a ball park figure of how much some items are going to cost? And also how much roughly its going to cost to have the work done.
Car hasn't been used since december, and i've just started it back up today and gave it a little run just to free it up a bit. What i now want to do is have a full check up on the car, and have a full service done.
Here are the things i'm planning on having sorted, please feel free to add anything you think i've missed ( Car is just on 51000 miles and has been Bpu for about the last 3000 miles )
Oil and filter change
Fuel filter
Power steering fluid
brake fluid
coolant
new discs and pads all round
geo setup
Price for above??????
Thanks
Oil and filter change - £50-£100 depending on oil
Fuel filter - £45 iirc from Toyota?
Power steering fluid - £10
brake fluid - £20
coolant - £30
new discs and pads all round - £350-400 for stock Discs with CW pads
geo setup - Approx £80 for Laser, not sure on full corner weight setup.
Thanks
Not sure what to allow for labour, I would probably take around 3/4 of a shift to do the service & brakes. Maybe a little more if things were siezed. I would be doing individual corners with the brakes though.
Could be expensive though at £100 per hour, depends on your hourly rate & how much you can do yourself :)
Spark Plugs - I do them every 2nd service, the Iridium ones are said to do many miles.
Window Wipers - If they aint broke don't fix
Gear Box fluid - £30
Belts are a good idea if they haven't been done recently.
Edited by Scott (see edit history)
