Guest Casinomgr Posted May 30, 2010 Share Posted May 30, 2010 I am running AEM on my 97 Supra plus a lot of other mods 664hp built by Dana at Virtual Works. I am looking at a Xtreme Obd 2 but I need the stock readings for the car so I can program my comupter . I am enclosing a link to the website and if you scroll down you will see what I need. Thank you, Alan http://www.immensehardware.com/electronics/xtreme-obd-2.html Quote Link to comment Share on other sites More sharing options...
Wez Posted May 30, 2010 Share Posted May 30, 2010 Can you still get odb2 output with an AEM installed? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 30, 2010 Share Posted May 30, 2010 Surly you can monitor all the sensors that are connected to the AEM through the logging/live software, which amounts to pretty much the same thing, Only the std ECU will have a normal OBD i think 1 in the case of the Supra. Quote Link to comment Share on other sites More sharing options...
Guest Casinomgr Posted May 30, 2010 Share Posted May 30, 2010 Stock Obd 2 is totally disconnected and you get no reading from it AEM doesn't support reading Obd so I have to get something that can be read by the smog check and was wondering what the stock readings are. If you click the link you can see what parts need to be filled in by my computer in the setup of the sensor. Like I said before I do run a cat converter and if they still used the wand in my tailpipe I would pass the smog. Thanks for replying. Quote Link to comment Share on other sites More sharing options...
