Wyntersun Posted May 28, 2010 Share Posted May 28, 2010 What's the best way to get the backlighting on my climate control brighter? Seems really dim looking compared to the rest of the dash. Matt Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2010 Share Posted May 28, 2010 Are the buttons yellowed in the daylight? They do tend to fade a fair bit on the older cars, especially aero ones. They should normally be bright enough to see at night though so something isn't quite right. New buttons can be bought from Toyota, they are reasonably inexpensive. Quote Link to comment Share on other sites More sharing options...
Wyntersun Posted May 28, 2010 Author Share Posted May 28, 2010 Cheers Homer, I think your right, they do look a bit yellowed on the button symbols. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2010 Share Posted May 28, 2010 Just edited above with some more info. Also, the back lights on that unit have several bulbs (3 I think), so it could be that one of more are blown, so add that to your check list Quote Link to comment Share on other sites More sharing options...
Wyntersun Posted May 28, 2010 Author Share Posted May 28, 2010 Thanks for the info Do you know where I can get the part numbers for the buttons etc? I did check the bulbs only last week and they seemed to be working. I think your right about the buttons being yellowed by the sun. Think I might need the temp and speed dial too. Quote Link to comment Share on other sites More sharing options...
Mcgoo Posted May 28, 2010 Share Posted May 28, 2010 Have a look at Heckler's site. He shows you how to fix the dry joints if you have them or you can change to LEDs. http://www.internetwork.org.uk/supra.htm Quote Link to comment Share on other sites More sharing options...
Wyntersun Posted May 28, 2010 Author Share Posted May 28, 2010 Excellent, thanks. Got the part numbers from there to Quote Link to comment Share on other sites More sharing options...
Wyntersun Posted May 28, 2010 Author Share Posted May 28, 2010 Just edited above with some more info. Also, the back lights on that unit have several bulbs (3 I think), so it could be that one of more are blown, so add that to your check list Actually I think its the bulbs that have gone. I only checked the 2 bulbs for the illumination of the fan speed and temp dial. Just checked Hecklers site and didn't realise the button illumination bulbs were under the plastic panel that needs to be removed. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 28, 2010 Share Posted May 28, 2010 Yep, the actual bulbs are behind the panel, forgot to mention that! Hopefully a simple (and cheap) fix to a simple problem Quote Link to comment Share on other sites More sharing options...
